AddPViewport 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 618| 评论: 0|原作者: admin|来自: AutoCAD
添加给定中心、高度和宽度的纸张空间视口。
RetVal = object.AddPViewport(Center, Width, Height)
类型: PaperSpace
此方法应用到的对象。
中心
访问:仅输入
类型:变体(双打的三元素阵列)
视口的中心坐标。
宽度
访问:仅输入
类型:双
视口的宽度。必须为正数。
高度
访问:仅输入
类型:双
视口的高度。必须为正数。
返回值 (RetVal)
类型: PViewport
新创建的对象。PViewport
Sub Example_AddPViewport()
    ' This example creates a new paper space viewport
    Dim pviewportObj As AcadPViewport
    Dim center(0 To 2) As Double
    Dim width As Double
    Dim height As Double
    ' Define the paper space viewport
    center(0) = 3: center(1) = 3: center(2) = 0
    width = 40
    height = 40
    ' Change from model space to paper space
    ThisDrawing.ActiveSpace = acPaperSpace
    ' Create the paper space viewport
    Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
(defun c:Example_AddPViewport()
    ;; This example creates a new paper space viewport
    ;; Define the paper space viewport
    (setq center (vlax-3d-point 3 3 0)
          width 40
          height 40)
    ;; Change from model space to paper space
    (vla-put-ActiveSpace doc acPaperSpace)
    ;; Create the paper space viewport
    (setq paperSpace (vla-get-PaperSpace doc))
    (setq pviewportObj (vla-AddPViewport paperSpace center width height))
    ;; Turn the viewport on, by default it is off
    (vla-Display pviewportObj :vlax-true)
GMT+8, 2026-10-27 04:59
