AddDimOrdinate 方法 (ActiveX)
在给定定义点和引线端点的情况下创建纵坐标维度。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddDimOrdinate(DefinitionPoint, LeaderEndPoint, UseXAxis) 言论纵坐标尺寸显示对象的 X 或 Y 坐标以及简单的引线。坐标的绝对值根据纵坐标尺寸的现行标准使用。 ![]() 测量与圆相切的点的绝对 X 位置的纵坐标维数 例子VBA: Sub Example_AddDimOrdinate()
' This example creates an ordinate dimension in model space.
Dim dimObj As AcadDimOrdinate
Dim definingPoint(0 To 2) As Double
Dim leaderEndPoint(0 To 2) As Double
Dim useXAxis As Long
' Define the dimension
definingPoint(0) = 5#: definingPoint(1) = 5#: definingPoint(2) = 0#
leaderEndPoint(0) = 10#: leaderEndPoint(1) = 5#: leaderEndPoint(2) = 0#
useXAxis = 5#
' Create an ordinate dimension in model space
Set dimObj = ThisDrawing.ModelSpace.AddDimOrdinate(definingPoint, leaderEndPoint, useXAxis)
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_AddDimOrdinate()
;; This example creates an ordinate dimension in model space.
;; Define the dimension
(setq definingPoint (vlax-3d-point 5 5 0)
leaderEndPoint (vlax-3d-point 10 5 0)
useXAxis 5)
;; Create an ordinate dimension in model space
(setq dimObj (vla-AddDimOrdinate modelSpace definingPoint leaderEndPoint useXAxis))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-27 05:09
