AddDimAngular 方法 (ActiveX)
为圆弧、两条线或一个圆创建角度尺寸。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddDimAngular(AngleVertex, FirstEndPoint, SecondEndPoint, TextPoint) 言论![]() 是圆或圆弧的中心,或被标注尺寸的两条线之间的公共顶点。 并且是两条延长线通过的点。AngleVertexFirstEndPointSecondEndPoint 可以与其中一个角度端点相同。如果您需要延长线,它们将自动添加。提供的端点用作延伸线的原点。AngleVertex 例子VBA: Sub Example_AddDimAngular()
' This example creates an angular dimension in model space.
Dim dimObj As AcadDimAngular
Dim angVert(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double
Dim SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
' Define the dimension
angVert(0) = 0#: angVert(1) = 5#: angVert(2) = 0#
FirstPoint(0) = 1#: FirstPoint(1) = 7#: FirstPoint(2) = 0#
SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
TextPoint(0) = 3#: TextPoint(1) = 5#: TextPoint(2) = 0#
' Create the angular dimension in model space
Set dimObj = ThisDrawing.ModelSpace.AddDimAngular(angVert, FirstPoint, SecondPoint, TextPoint)
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_AddDimAngular()
;; This example creates an angular dimension in model space.
;; Define the dimension
(setq angVert (vlax-3d-point 0 5 0)
FirstPoint (vlax-3d-point 1 7 0)
SecondPoint (vlax-3d-point 1 3 0)
TextPoint (vlax-3d-point 3 5 0))
;; Create the angular dimension in model space
(setq dimObj (vla-AddDimAngular modelSpace angVert FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-27 05:16
