AddBox 方法 (ActiveX)
2024-5-18 16:53| 发布者: admin| 查看: 763| 评论: 0|原作者: admin|来自: AutoCAD
AddBox 方法 (ActiveX)
创建一个边平行于 WCS 轴的 3D 实体框。
RetVal = object.AddBox(Origin, Length, Width, Height)
类型:块、模型空间、纸空间
此方法应用到的对象。
起源
访问:仅输入
类型:变体(双打的三元素阵列)
指定盒子原点的 3D WCS 坐标。此坐标表示对象的边界框的中心,而不是角。
长度
访问:仅输入
类型:双
盒子的长度。必须为正数。
宽度
访问:仅输入
类型:双
框的宽度。必须为正数。
高度
访问:仅输入
类型:双
盒子的高度。必须为正数。
返回值 (RetVal)
类型: 3DSolid
作为新创建的框的对象。3DSolid
Sub Example_AddBox()
    ' This example creates a box in model space.
    Dim boxObj As Acad3DSolid
    Dim length As Double, width As Double, height As Double
    Dim center(0 To 2) As Double
    ' Define the box
    center(0) = 5#: center(1) = 5#: center(2) = 0
    length = 5#: width = 7: height = 10#
    ' Create the box (3DSolid) object in model space
    Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
    ' Change the viewing direction of the viewport to better see the box
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
(defun c:Example_AddBox()
    ;; This example creates a box in model space.
    ;; Define the box
    (setq center (vlax-3d-point 5 5 0)
          boxLength 5
	         boxWidth 7
	         boxHeight 10)
    ;; Create the box (3DSolid) object in model space
    (setq boxObj (vla-AddBox modelSpace center boxLength boxWidth boxHeight))
    ;; Change the viewing direction of the viewport to better see the box
    (setq NewDirection (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
    (vla-ZoomAll acadObj)
GMT+8, 2026-10-27 12:37
