AddAttribute 方法 (ActiveX)
在给定位置创建具有指定属性的属性定义。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddAttribute(Height, Mode, Prompt, InsertionPoint, Tag, Value)
言论属性定义与为其创建属性定义的块相关联。在模型空间或图纸空间中创建的属性定义不被视为附加到任何给定块。 AutoCAD AFLAGS 系统变量存储模式设置。您可以使用该方法查询此值,也可以使用该方法设置该值。GetVariableSetVariable 例子VBA: Sub Example_AddAttribute()
' This example creates an attribute definition in model space.
Dim attributeObj As AcadAttribute
Dim height As Double
Dim mode As Long
Dim prompt As String
Dim tag As String
Dim value As String
' Define the attribute definition
height = 1#
mode = acAttributeModeVerify
prompt = "New Prompt"
insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
tag = "NEW_TAG"
value = "New Value"
' Create the attribute definition object in model space
Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_AddAttribute()
;; This example creates an attribute definition in model space.
;; Define the attribute definition
(setq insertionPoint (vlax-3d-point 5 5 0)
attHeight 1
attMode acAttributeModeVerify
attPrompt "New Prompt"
attTag "NEW_TAG"
attValue "New Value")
;; Create the attribute definition object in model space
(setq attributeObj (vla-AddAttribute modelSpace attHeight attMode attPrompt insertionPoint attTag attValue))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-26 23:52
