AddArc 方法 (ActiveX)
根据圆弧的中心角、半径、起始角和结束角创建圆弧。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddArc(Center, Radius, StartAngle, EndAngle) 言论没有其他评论。 例子VBA: Sub Example_AddArc()
' This example creates an arc in model space.
Dim arcObj As AcadArc
Dim radius As Double
Dim startAngleInDegree As Double
Dim endAngleInDegree As Double
' Define the circle
centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#
radius = 5#
startAngleInDegree = 10#
endAngleInDegree = 230#
' Convert the angles in degrees to angles in radians
Dim startAngleInRadian As Double
Dim endAngleInRadian As Double
startAngleInRadian = startAngleInDegree * 3.141592 / 180#
endAngleInRadian = endAngleInDegree * 3.141592 / 180#
' Create the arc object in model space
Set arcObj = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngleInRadian, endAngleInRadian)
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_AddArc()
;; This example creates an arc in model space.
;; Define the arc
(setq centerPoint (vlax-3d-point 0 0 0)
radius 5
startAngleInDegree 10
endAngleInDegree 230)
;; Convert the angles in degrees to angles in radians
(setq startAngleInRadian (/ (* startAngleInDegree 3.141592) 180))
(setq endAngleInRadian (/ (* endAngleInDegree 3.141592) 180))
;; Create the arc object in model space
(setq arcObj (vla-AddArc modelSpace centerPoint radius startAngleInRadian endAngleInRadian))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-27 04:35
