Activate 方法 (ActiveX)
使指定的图形处于活动状态。 支持的平台:仅限 Windows 返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_ActivateMethod()
' This example creates two new drawings and activates each drawing in turn.
Dim NewDrawing1 As AcadDocument
Dim Newdrawing2 As AcadDocument
Set NewDrawing1 = ThisDrawing.Application.Documents.Add("")
Set Newdrawing2 = ThisDrawing.Application.Documents.Add("")
Dim drawing As AcadDocument
For Each drawing In ThisDrawing.Application.Documents
drawing.Activate
MsgBox "Drawing " & drawing.name & " is active."
Next drawing
可视化 LISP: Not available |
GMT+8, 2026-11-15 11:39
