若要复制对象,请使用为该对象提供的函数。此方法创建一个新对象,该对象是原始对象的副本。创建重复对象后,可以在将其添加或追加到数据库之前对其进行修改。如果不变换对象或更改其位置,则新对象将位于与原始对象相同的位置。Clone 如果要复制大量对象,则可以将每个对象 ID 添加到对象中,然后循环访问每个对象。在循环访问每个对象时,可以对每个对象使用该函数,然后将新对象添加或追加到数据库中。ObjectIdCollectionClone 复制单个对象下面的示例创建一个新圆,然后创建该圆的直接副本以创建第二个圆。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("SingleCopy")> _
Public Sub SingleCopy()
'' Start a transaction
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a circle that is at 2,3 with a radius of 4.25
Using acCirc As Circle = New Circle()
acCirc.Center = New Point3d(2, 3, 0)
acCirc.Radius = 4.25
acBlkTblRec.AppendEntity(acCirc)
acTrans.AddNewlyCreatedDBObject(acCirc, True)
'' Create a copy of the circle and change its radius
Dim acCircClone As Circle = acCirc.Clone()
acCircClone.Radius = 1
'' Add the cloned circle
acBlkTblRec.AppendEntity(acCircClone)
acTrans.AddNewlyCreatedDBObject(acCircClone, True)
End Using
'' Save the new object to the database
acTrans.Commit()
End Using
[CommandMethod("SingleCopy")]
public static void SingleCopy()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a circle that is at 2,3 with a radius of 4.25
using (Circle acCirc = new Circle())
acCirc.Center = new Point3d(2, 3, 0);
acCirc.Radius = 4.25;
acBlkTblRec.AppendEntity(acCirc);
acTrans.AddNewlyCreatedDBObject(acCirc, true);
// Create a copy of the circle and change its radius
Circle acCircClone = acCirc.Clone() as Circle;
acCircClone.Radius = 1;
// Add the cloned circle
acBlkTblRec.AppendEntity(acCircClone);
acTrans.AddNewlyCreatedDBObject(acCircClone, true);
// Save the new object to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub SingleCopy()
' Define the Circle object
centerPoint(0) = 2: centerPoint(1) = 3: centerPoint(2) = 0
' Define the radius for the initial circle
Dim radius As Double
radius = 4.25
' Define the radius for the copied circle
Dim radiusCopy As Double
radiusCopy = 1#
' Add the new circle to model space
Dim circleObj As AcadCircle
Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
Dim circleObjCopy As AcadCircle
Set circleObjCopy = circleObj.Copy()
circleObjCopy.radius = radiusCopy
复制多个对象下面的示例使用对象来跟踪应复制的对象。将对象 ID 添加到集合后,将迭代该集合,并使用该方法创建新对象,然后将其添加到模型空间。ObjectIdCollectionClone VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("MultipleCopy")> _
Public Sub MultipleCopy()
OpenMode.ForWrite)
'' Create a circle that is at (0,0,0) with a radius of 5
Using acCirc1 As Circle = New Circle()
acCirc1.Center = New Point3d(0, 0, 0)
acCirc1.Radius = 5
acBlkTblRec.AppendEntity(acCirc1)
acTrans.AddNewlyCreatedDBObject(acCirc1, True)
'' Create a circle that is at (0,0,0) with a radius of 7
Using acCirc2 As Circle = New Circle()
acCirc2.Center = New Point3d(0, 0, 0)
acCirc2.Radius = 7
acBlkTblRec.AppendEntity(acCirc2)
acTrans.AddNewlyCreatedDBObject(acCirc2, True)
'' Add all the objects to clone
Dim acDBObjColl As DBObjectCollection = New DBObjectCollection()
acDBObjColl.Add(acCirc1)
acDBObjColl.Add(acCirc2)
For Each acEnt As Entity In acDBObjColl
Dim acEntClone As Entity
acEntClone = acEnt.Clone()
acEntClone.ColorIndex = 1
'' Create a matrix and move each copied entity 15 units
acEntClone.TransformBy(Matrix3d.Displacement(New Vector3d(15, 0, 0)))
'' Add the cloned object
acBlkTblRec.AppendEntity(acEntClone)
acTrans.AddNewlyCreatedDBObject(acEntClone, True)
Next
End Using
End Using
acTrans.Commit()
End Using
[CommandMethod("MultipleCopy")]
public static void MultipleCopy()
// Create a circle that is at (0,0,0) with a radius of 5
using (Circle acCirc1 = new Circle())
acCirc1.Center = new Point3d(0, 0, 0);
acCirc1.Radius = 5;
acBlkTblRec.AppendEntity(acCirc1);
acTrans.AddNewlyCreatedDBObject(acCirc1, true);
// Create a circle that is at (0,0,0) with a radius of 7
using (Circle acCirc2 = new Circle())
acCirc2.Center = new Point3d(0, 0, 0);
acCirc2.Radius = 7;
acBlkTblRec.AppendEntity(acCirc2);
acTrans.AddNewlyCreatedDBObject(acCirc2, true);
// Add all the objects to clone
DBObjectCollection acDBObjColl = new DBObjectCollection();
acDBObjColl.Add(acCirc1);
acDBObjColl.Add(acCirc2);
foreach (Entity acEnt in acDBObjColl)
Entity acEntClone;
acEntClone = acEnt.Clone() as Entity;
acEntClone.ColorIndex = 1;
// Create a matrix and move each copied entity 15 units
acEntClone.TransformBy(Matrix3d.Displacement(new Vector3d(15, 0, 0)));
// Add the cloned object
acBlkTblRec.AppendEntity(acEntClone);
acTrans.AddNewlyCreatedDBObject(acEntClone, true);
acTrans.Commit();
VBA/ActiveX 代码参考Sub MultipleCopy()
centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
Dim radius1 As Double, radius2 As Double
radius1 = 5#: radius2 = 7#
' Add two circles to the current drawing
Dim circleObj1 As AcadCircle, circleObj2 As AcadCircle
Set circleObj1 = ThisDrawing.ModelSpace.AddCircle _
(centerPoint, radius1)
Set circleObj2 = ThisDrawing.ModelSpace.AddCircle _
(centerPoint, radius2)
' First put the objects to be copied into a form compatible
' with CopyObjects
Dim objCollection(0 To 1) As Object
Set objCollection(0) = circleObj1
Set objCollection(1) = circleObj2
' Copy the objects into the model space. A
' collection of the new (copied) objects is returned.
Dim retObjects As Variant
retObjects = ThisDrawing.CopyObjects(objCollection)
Dim ptFrom(0 To 2) As Double
ptFrom(0) = 0: ptFrom(1) = 0: ptFrom(2) = 0
Dim ptTo(0 To 2) As Double
ptTo(0) = 15: ptTo(1) = 0: ptTo(2) = 0
Dim nCount As Integer
For nCount = 0 To UBound(retObjects)
Dim entObj As AcadEntity
Set entObj = retObjects(nCount)
entObj.color = acRed
entObj.Move ptFrom, ptTo
Next
相关概念父主题: |
GMT+8, 2026-10-31 07:49
