可以随时从数据库中清除未引用的命名对象。不能清除由其他对象引用的命名对象。例如,字体文件可能由文本样式引用,或者图层上的对象可能被引用。清除可在保存到磁盘时减小图形文件的大小。 未参照的对象将使用该方法从图形数据库中清除。该方法需要要以 或 objects 的形式清除的对象列表。传递到方法中的 or 对象将使用可以从数据库中删除的对象进行更新。调用 后,必须擦除返回的每个对象。PurgePurgeObjectIdCollectionObjectIdGraphObjectIdCollectionObjectIdGraphPurgePurge 清除所有未参照的图层以下示例演示了如何从数据库中清除所有未引用的图层。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("PurgeUnreferencedLayers")> _
Public Sub PurgeUnreferencedLayers()
'' Start a transaction
'' Open the Layer table for read
Dim acLyrTbl As LayerTable
acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
OpenMode.ForRead)
'' Create an ObjectIdCollection to hold the object ids for each table record
Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection()
'' Step through each layer and add it to the ObjectIdCollection
For Each acObjId As ObjectId In acLyrTbl
acObjIdColl.Add(acObjId)
Next
'' Remove the layers that are in use and return the ones that can be erased
acCurDb.Purge(acObjIdColl)
'' Step through the returned ObjectIdCollection
For Each acObjId As ObjectId In acObjIdColl
Dim acSymTblRec As SymbolTableRecord
acSymTblRec = acTrans.GetObject(acObjId, _
OpenMode.ForWrite)
Try
'' Erase the unreferenced layer
acSymTblRec.Erase(True)
Catch Ex As Autodesk.AutoCAD.Runtime.Exception
'' Layer could not be deleted
Application.ShowAlertDialog("Error:" & vbLf & Ex.Message)
End Try
Next
'' Commit the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("PurgeUnreferencedLayers")]
public static void PurgeUnreferencedLayers()
// Start a transaction
// Open the Layer table for read
LayerTable acLyrTbl;
OpenMode.ForRead) as LayerTable;
// Create an ObjectIdCollection to hold the object ids for each table record
ObjectIdCollection acObjIdColl = new ObjectIdCollection();
// Step through each layer and add iterator to the ObjectIdCollection
foreach (ObjectId acObjId in acLyrTbl)
acObjIdColl.Add(acObjId);
// Remove the layers that are in use and return the ones that can be erased
acCurDb.Purge(acObjIdColl);
// Step through the returned ObjectIdCollection
// and erase each unreferenced layer
foreach (ObjectId acObjId in acObjIdColl)
SymbolTableRecord acSymTblRec;
OpenMode.ForWrite) as SymbolTableRecord;
try
// Erase the unreferenced layer
acSymTblRec.Erase(true);
catch (Autodesk.AutoCAD.Runtime.Exception Ex)
// Layer could not be deleted
Application.ShowAlertDialog("Error:\n" + Ex.Message);
// Commit the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 交叉引用在 ActiveX 自动化库中,您将使用该方法删除所有未引用的命名对象,并标识可以删除哪些对象。但是,使用 AutoCAD .NET API 时,您需要提供要清除的对象,然后该方法会返回给您实际可以清除的对象。因此,在使用 AutoCAD .NET API 从数据库中清除所有未引用的命名对象时,需要做更多的工作。PurgeAllPurge ThisDrawing.PurgeAll 相关概念父主题: |
GMT+8, 2026-10-31 08:46
