选择筛选器由成对的参数组成,其形式为 。a 的第一个参数标识筛选器的类型(例如,对象),第二个参数指定要筛选的值(例如,圆)。筛选器类型是指定要使用的筛选器的 DXF 组代码。此处列出了一些最常见的过滤器类型。TypedValuesTypedValue
为选择集指定单个选择条件以下代码提示用户选择要包含在选择集中的对象,并筛选出除圆圈之外的所有对象。 VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("FilterSelectionSet")> _
Public Sub FilterSelectionSet()
'' Get the current document editor
Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
'' Create a TypedValue array to define the filter criteria
Dim acTypValAr(0) As TypedValue
acTypValAr.SetValue(New TypedValue(DxfCode.Start, "CIRCLE"), 0)
'' Assign the filter criteria to a SelectionFilter object
Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
'' Request for objects to be selected in the drawing area
Dim acSSPrompt As PromptSelectionResult
acSSPrompt = acDocEd.GetSelection(acSelFtr)
'' If the prompt status is OK, objects were selected
If acSSPrompt.Status = PromptStatus.OK Then
Dim acSSet As SelectionSet = acSSPrompt.Value
Application.ShowAlertDialog("Number of objects selected: " & _
acSSet.Count.ToString())
Else
Application.ShowAlertDialog("Number of objects selected: 0")
End If
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("FilterSelectionSet")]
public static void FilterSelectionSet()
// Get the current document editor
Editor acDocEd = Application.DocumentManager.MdiActiveDocument.Editor;
// Create a TypedValue array to define the filter criteria
TypedValue[] acTypValAr = new TypedValue[1];
acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "CIRCLE"), 0);
// Assign the filter criteria to a SelectionFilter object
SelectionFilter acSelFtr = new SelectionFilter(acTypValAr);
// Request for objects to be selected in the drawing area
PromptSelectionResult acSSPrompt;
acSSPrompt = acDocEd.GetSelection(acSelFtr);
// If the prompt status is OK, objects were selected
if (acSSPrompt.Status == PromptStatus.OK)
SelectionSet acSSet = acSSPrompt.Value;
Application.ShowAlertDialog("Number of objects selected: " +
acSSet.Count.ToString());
else
Application.ShowAlertDialog("Number of objects selected: 0");
VBA/ActiveX 代码参考Sub FilterSelectionSet()
' Create a new selection set
Dim sset As AcadSelectionSet
Set sset = ThisDrawing.SelectionSets.Add("SS1")
' Define the filter list, only Circle objects
' will be selectable
Dim FilterType(0) As Integer
Dim FilterData(0) As Variant
FilterType(0) = 0
FilterData(0) = "Circle"
' Prompt the user to select objects
' and add them to the selection set
sset.SelectOnScreen FilterType, FilterData
MsgBox "Number of objects selected: " & sset.Count
' Remove the selection set at the end
sset.Delete
相关概念父主题: | ||||||||||||||||
GMT+8, 2026-10-27 22:00
