示例:列出 Excel 电子表格上的 AutoCAD 特性 (VBA/ActiveX)
2024-5-18 16:52| 发布者: admin| 查看: 892| 评论: 0|原作者: admin|来自: AutoCAD
此示例子例程查找当前图形中的所有块参照。
然后,它会查找附加到这些块引用的属性,并在 Excel 电子表格中列出它们。若要运行此示例,请执行以下操作:
  1. 打开包含带属性的块参照的图形。(示例图形 sample/activeX/attrib.dwg 包含此类块参照。
  2. 在AutoCAD命令提示下,输入VBAIDE,然后按Enter键。
    将显示 VBA IDE。
  3. 在 VBA IDE 的菜单栏上,单击“工具”菜单 “References”。
  4. 在“引用”对话框中,选择“Microsoft Excel <version_number>对象模型”。单击“确定”。
  5. 将以下子例程复制到 VBA 代码窗口中并运行它。
    Sub ExtractAtts()
      Dim Excel As Excel.Application
      Dim ExcelSheet As Object
      Dim ExcelWorkbook As Object
      Dim RowNum As Integer
      Dim Header As Boolean
      Dim elem As AcadEntity
      Dim Array1 As Variant
      Dim Count As Integer
      ' Launch Excel.
      Set Excel = New Excel.Application
      ' Create a new workbook and find the active sheet.
      Set ExcelWorkbook = Excel.Workbooks.Add
      Set ExcelSheet = Excel.ActiveSheet
      ExcelWorkbook.SaveAs "Attribute.xls"
      RowNum = 1
      Header = False
      ' Iterate through model space finding
      ' all block references.
      For Each elem In ThisDrawing.ModelSpace
        With elem
          ' When a block reference has been found,
          ' check it for attributes
          If StrComp(.EntityName, "AcDbBlockReference", 1) = 0 Then
            If .HasAttributes Then
              ' Get the attributes
              Array1 = .GetAttributes
              ' Copy the Tagstrings for the
              ' Attributes into Excel
              For Count = LBound(Array1) To UBound(Array1)
                If Header = False Then
                  If StrComp(Array1(Count).EntityName, "AcDbAttribute", 1) = 0 Then
                    ExcelSheet.Cells(RowNum, Count + 1).value = Array1(Count).TagString
                  End If
                End If
              Next Count
              RowNum = RowNum + 1
                ExcelSheet.Cells(RowNum, Count + 1).value = Array1(Count).textString
              Next Count
              Header = True
            End If
          End If
        End With
      Next elem
      Excel.Application.Quit
GMT+8, 2026-10-27 08:16
