关于分配和检索扩展数据 (VBA/ActiveX)
可以使用扩展数据 (xdata) 作为将信息与图形中的对象链接的方法。 将 xdata 分配给选择集中的所有对象本示例提示用户从图形中选取对象。所选对象将放置到选择集中,并且指定的 xdata 将附加到该选择集中的所有对象。 Sub Ch10_AttachXDataToSelectionSetObjects()
' Create the selection set
Dim sset As Object
Set sset = ThisDrawing.SelectionSets.Add("SS1")
' Prompt the user to select objects
sset.SelectOnScreen
' Define the xdata
Dim appName As String, xdataStr As String
appName = "MY_APP"
xdataStr = "This is some xdata"
Dim xdataType(0 To 1) As Integer
Dim xdata(0 To 1) As Variant
' Define the values for each array
'1001 indicates the appName
xdataType(0) = 1001
xdata(0) = appName
'1000 indicates a string value
xdataType(1) = 1000
xdata(1) = xdataStr
' Loop through all entities in the selection
' set and assign the xdata to each entity
Dim ent As Object
For Each ent In sset
ent.SetXData xdataType, xdata
Next ent
查看选择集中所有对象的 xdata此示例显示与上一个示例一起附加的 xdata。如果附加字符串以外的 xdata(类型 1000),则需要修改此代码。 Sub Ch10_ViewXData()
' Find the selection created in previous example
Dim sset As Object
Set sset = ThisDrawing.SelectionSets.Item("SS1")
' Define the xdata variables to hold xdata information
Dim xdataType As Variant
Dim xdata As Variant
Dim xd As Variant
'Define index counter
Dim xdi As Integer
xdi = 0
' Loop through the objects in the selection set
' and retrieve the xdata for the object
Dim msgstr As String
Dim ent As AcadEntity
appName = "MY_APP"
msgstr = ""
xdi = 0
' Retrieve the appName xdata type and value
ent.GetXData appName, xdataType, xdata
' If the xdataType variable is not initialized, there
' was no appName xdata to retrieve for that entity
If VarType(xdataType) <> vbEmpty Then
For Each xd In xdata
msgstr = msgstr & vbCrLf & xdataType(xdi) _
& ": " & xd
xdi = xdi + 1
Next xd
End If
' If the msgstr variable is NULL, there was no xdata
If msgstr = "" Then msgstr = vbCrLf & "NONE"
MsgBox appName & " xdata on " & ent.ObjectName & _
":" & vbCrLf & msgstr
Next ent
GMT+8, 2026-10-27 05:45
