关于提取属性信息 (VBA/ActiveX)
2024-5-18 16:52| 发布者: admin| 查看: 476| 评论: 0|原作者: admin|来自: AutoCAD
可以使用 和 方法从图形中提取属性信息。GetAttributesGetConstantAttributes
该方法返回附加到块的属性引用的数组及其当前值。该方法返回附加到模块或外部引用的常量属性数组。此方法返回的属性是常量属性定义,而不是属性引用。GetAttributesGetConstantAttributes
您不需要模板文件来提取属性信息,也不会创建任何属性信息文件。只需迭代属性引用数组,使用属性 -reference 的 and 属性来检查属性信息。TagStringTextString
该属性表示属性引用的单个标记。该属性包含属性引用的值。TagStringTextString
获取属性参考信息
此示例创建一个块,然后向该块添加一个属性。然后将块插入到图形中。然后,使用消息框返回并显示属性数据。然后更新块引用的属性数据,并再次返回并显示属性数据。
Sub Ch10_GettingAttributes()
 ' Create the block
 Dim blockObj As AcadBlock
 Dim insertionPnt(0 To 2) As Double
 insertionPnt(0) = 0
 insertionPnt(1) = 0
 insertionPnt(2) = 0
 Set blockObj = ThisDrawing.Blocks.Add _
 (insertionPnt, "TESTBLOCK")
 ' Define the attribute definition
 Dim attributeObj As AcadAttribute
 Dim height As Double
 Dim mode As Long
 Dim prompt As String
 Dim tag As String
 Dim value As String
 height = 1#
 mode = acAttributeModeVerify
 prompt = "Attribute Prompt"
 insertionPoint(0) = 5
 insertionPoint(1) = 5
 insertionPoint(2) = 0
 tag = "Attribute Tag"
 value = "Attribute Value"
 ' Create the attribute definition object on the block
 Set attributeObj = blockObj.AddAttribute _
 (height, mode, prompt, _
 insertionPoint, tag, value)
 ' Insert the block
 Dim blockRefObj As AcadBlockReference
 insertionPnt(0) = 2
 insertionPnt(1) = 2
 insertionPnt(2) = 0
 Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock _
 (insertionPnt, "TESTBLOCK", 1, 1, 1, 0)
 ZoomAll
 ' Get the attributes for the block reference
 Dim varAttributes As Variant
 varAttributes = blockRefObj.GetAttributes
 ' Move the attribute tags and values into a
 ' string to be displayed in a Msgbox
 Dim strAttributes As String
 strAttributes = ""
 Dim I As Integer
 For I = LBound(varAttributes) To UBound(varAttributes)
 strAttributes = strAttributes + "  Tag: " + _
 varAttributes(I).TagString + vbCrLf + _
 "   Value: " + varAttributes(I).textString
 Next
 MsgBox "The attributes for blockReference " + _
 blockRefObj.Name & " are: " & vbCrLf _
 & strAttributes
 ' Change the value of the attribute
 ' Note: There is no SetAttributes. Once you have the
 ' variant array, you have the objects.
 ' Changing them changes the objects in the drawing.
 varAttributes(0).textString = "NEW VALUE!"
 ' Get the attributes again
 Dim newvarAttributes As Variant
 newvarAttributes = blockRefObj.GetAttributes
 ' Again, display the tags and values
 strAttributes = ""
 newvarAttributes(I).TagString + vbCrLf + _
 "   Value: " + newvarAttributes(I).textString
 Next
 MsgBox "The attributes for blockReference " & _
 & strAttributes
GMT+8, 2026-10-27 07:39
