关于重新定义块 (VBA/ActiveX)
2024-5-18 16:52| 发布者: admin| 查看: 885| 评论: 0|原作者: admin|来自: AutoCAD
使用任何对象方法和属性来重新定义块。Block
重新定义块时,图形中对该块的所有参照都会立即更新以反映新定义。
重新定义会影响块的先前和未来插入。常量属性将丢失,并被任何新的常量属性替换。即使新块没有属性,变量属性也保持不变。
重新定义块定义中的对象
此示例创建一个块,并在该块的定义中添加一个圆圈。然后,将块作为块参照插入到图形中。模块定义中的圆圈将更新,块参照将自动更新。
Sub Ch10_RedefiningABlock()
 ' Define the block
 Dim blockObj As AcadBlock
 Dim insertionPnt(0 To 2) As Double
 insertionPnt(0) = 0
 insertionPnt(1) = 0
 insertionPnt(2) = 0
 Set blockObj = ThisDrawing.Blocks.Add _
 (insertionPnt, "CircleBlock")
 ' Add a circle to the block
 Dim circleObj As AcadCircle
 Dim center(0 To 2) As Double
 Dim radius As Double
 center(0) = 0
 center(1) = 0
 center(2) = 0
 radius = 1
 Set circleObj = blockObj.AddCircle(center, radius)
 ' Insert the block
 Dim blockRefObj As AcadBlockReference
 insertionPnt(0) = 2
 insertionPnt(1) = 2
 insertionPnt(2) = 0
 Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock _
 (insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
 ZoomAll
 ' Redefine the circle in the block,
 ' and update the block reference
 circleObj.radius = 3
 blockRefObj.Update
GMT+8, 2026-10-27 00:41
