关于 3D 阵列 (VBA/ActiveX)
使用该方法,您可以在 3D 中创建一个矩形数组。ArrayRectangular 除了指定列数(X 方向)和行数(Y 方向)之外,还可以指定级别数(Z 方向)。 创建 3D 矩形阵列本示例创建一个圆,然后使用该圆创建一个包含四行、四列和三级圆的矩形数组。 Sub Ch8_CreateRectangularArray()
' Create the circle
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 2: center(1) = 2: center(2) = 0
radius = 0.5
Set circleObj = ThisDrawing.ModelSpace. _
AddCircle(center, radius)
' Define the rectangular array
Dim numberOfRows As Long
Dim numberOfColumns As Long
Dim numberOfLevels As Long
Dim distanceBwtnRows As Double
Dim distanceBwtnColumns As Double
Dim distanceBwtnLevels As Double
numberOfRows = 4
numberOfColumns = 4
numberOfLevels = 3
distanceBwtnRows = 1
distanceBwtnColumns = 1
distanceBwtnLevels = 4
' Create the array of objects
Dim retObj As Variant
retObj = circleObj.ArrayRectangular _
(numberOfRows, numberOfColumns, _
numberOfLevels, distanceBwtnRows, _
distanceBwtnColumns, distanceBwtnLevels)
ZoomAll
GMT+8, 2026-10-27 01:23
