关于启用应用程序级事件 (VBA/ActiveX)
2024-5-18 16:52| 发布者: admin| 查看: 803| 评论: 0|原作者: admin|来自: AutoCAD
在使用应用程序级事件之前,必须创建一个新的类模块,并使用事件声明一个类型的对象。AcadApplication
例如,假定创建了一个新的类模块并命名为 EventClassModule。新的类模块包含使用 VBA 关键字的应用程序声明。WithEvents
将图形拖放到 AutoCAD 中时提示继续
本示例在将文件拖放到 AutoCAD 中时截获加载过程。一个消息框,其中包含删除的文件的名称和“是/否/继续”按钮,允许用户决定是否应继续加载或显示文件。如果用户选择取消操作,则通过事件的 Cancel 参数返回该决定,并且不会加载文件。BeginFileDrop
Public WithEvents ACADApp As AcadApplication
Sub Example_AcadApplication_Events()
 ' This example intializes the public variable (ACADApp)
 ' which will be used to intercept AcadApplication Events
 ' Run this procedure FIRST!
 ' We could get the application from the ThisDocument
 ' object, but that would require having a drawing open,
 ' so we grab it from the system.
 Set ACADApp = GetObject(, "AutoCAD.Application.22")
Private Sub ACADApp_BeginFileDrop _
 (ByVal FileName As String, Cancel As Boolean)
 ' This example intercepts an Application BeginFileDrop event.
 ' This event is triggered when a drawing file is dragged
 ' into AutoCAD.
 ' To trigger this example event:
 '     1) Make sure to run the example that initializes
 '     the public variable (named ACADApp) linked to this event.
 '     2) Drag an AutoCAD drawing file into the AutoCAD
 '        application from either the Windows Desktop
 '        or Windows Explorer
 ' Use the "Cancel" variable to stop the loading of the
 ' dragged file, and the "FileName" variable to  notify
 ' the user which file is about to be dragged in.
 If MsgBox("AutoCAD is about to load " & FileName & vbCrLf _
 & "Do you want to continue loading this file?", _
 vbYesNoCancel + vbQuestion) <> vbYes Then
 Cancel = True
 End If
GMT+8, 2026-11-15 13:41
