关于创建浮出控件工具栏 (VBA/ActiveX)
若要将浮出控件工具栏按钮添加到工具栏,请使用该方法。此方法创建一个新对象并将其添加到指定的工具栏中。AddToolbarButtonToolbarItem 该方法采用五个参数作为输入:Index、Name、HelpString、Macro 和 FlyoutButton。通过将 FlyoutButton 参数设置为 TRUE,新按钮将创建为浮出控件按钮。此方法的返回值将是新的浮出控件工具栏。然后,可以像普通工具栏一样填充浮出控件工具栏。AddToolbarButton 创建浮出控件工具栏按钮本示例创建两个工具栏。第一个工具栏包含浮出控件按钮。第二个工具栏附加到第一个工具栏上的浮出控件按钮。 Sub Ch6_AddFlyoutButton()
Dim currMenuGroup As AcadMenuGroup
Set currMenuGroup = ThisDrawing.Application. _
MenuGroups.Item(0)
' Create the first toolbar
Dim FirstToolbar As AcadToolbar
Set FirstToolbar = currMenuGroup.Toolbars. _
Add("FirstToolbar")
' Add a flyout button to the first menu on the menu bar
Dim FlyoutButton As AcadToolbarItem
Set FlyoutButton = FirstToolbar.AddToolbarButton _
("", "Flyout", "Demonstrates a flyout button", _
"OPEN", True)
' Create the second toolbar. This will be attached to
' the first toolbar through the flyout button.
Dim SecondToolbar As AcadToolbar
Set SecondToolbar = currMenuGroup.Toolbars. _
Add("SecondToolbar")
' Add a button to the next toolbar
Dim newButton As AcadToolbarItem
Dim openMacro As String
' Assign the macro the VB equivalent of "ESC ESC _open "
openMacro = Chr(3) + Chr(3) + "_open "
Set newButton = SecondToolbar.AddToolbarButton _
("", "NewButton", "Open a file.", openMacro)
' Attach the second toolbar to the flyout
' button on the first toolbar
FlyoutButton.AttachToolbarToFlyout currMenuGroup.Name, _
SecondToolbar.Name
' Display the first toolbar, hide the second toolbar
FirstToolbar.Visible = True
SecondToolbar.Visible = False
GMT+8, 2026-10-27 04:32
