ObjectARX 开发指南
创建复合区域 (.NET)
2023-1-1 14:48| 发布者: admin| 查看: 1935| 评论: 0|来自: AutoCAD
您可以通过减去、合并或查找区域或 3D 实体的交点来创建复合区域。然后,可以拉伸或旋转复合区域以创建复杂的实体。若要创建复合区域,请使用以下方法。BooleanOperation
减去区域
当您从一个区域中减去另一个区域时,您可以从第一个区域调用该方法。这是要从中减去的区域。例如,若要计算楼层平面图需要多少地毯,请从楼层空间的外部边界调用该方法,并将未铺设地毯的区域(如柱子和柜台)用作布尔参数列表中的对象。BooleanOperationBooleanOperation
联合区域
若要统一区域,请调用该方法并使用常量进行操作,而不是 。您可以按任意顺序组合区域以统一它们。BooleanOperationBooleanOperationType.BoolUniteBooleanOperationType.BoolSubtract
查找两个区域的交集
若要查找两个区域的交集,请使用常量 。您可以按任意顺序组合区域以与它们相交。BooleanOperationType.BoolIntersect
创建复合区域
下面的示例从两个圆中创建两个区域,然后从大圆中减去较小的区域以创建一个轮子。
VB.NET
<CommandMethod("CreateCompositeRegions")> _
Public Sub CreateCompositeRegions()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create two in memory circles
        Using acCirc1 As Circle = New Circle()
            acCirc1.Center = New Point3d(4, 4, 0)
            acCirc1.Radius = 2
            Using acCirc2 As Circle = New Circle()
                acCirc2.Center = New Point3d(4, 4, 0)
                acCirc2.Radius = 1
                '' Adds the circle to an object array
                Dim acDBObjColl As DBObjectCollection = New DBObjectCollection()
                acDBObjColl.Add(acCirc1)
                acDBObjColl.Add(acCirc2)
                '' Calculate the regions based on each closed loop
                Dim myRegionColl As DBObjectCollection = New DBObjectCollection()
                myRegionColl = Region.CreateFromCurves(acDBObjColl)
                Dim acRegion1 As Region = myRegionColl(0)
                Dim acRegion2 As Region = myRegionColl(1)
                '' Subtract region 1 from region 2
                If acRegion1.Area > acRegion2.Area Then
                    '' Subtract the smaller region from the larger one
                    acRegion1.BooleanOperation(BooleanOperationType.BoolSubtract, acRegion2)
                    acRegion2.Dispose()
                    '' Add the final region to the database
                    acBlkTblRec.AppendEntity(acRegion1)
                    acTrans.AddNewlyCreatedDBObject(acRegion1, True)
                Else
                    acRegion2.BooleanOperation(BooleanOperationType.BoolSubtract, acRegion1)
                    acRegion1.Dispose()
                    acBlkTblRec.AppendEntity(acRegion2)
                    acTrans.AddNewlyCreatedDBObject(acRegion2, True)
                End If
                '' Dispose of the in memory objects not appended to the database
            End Using
        End Using
        '' Save the new object to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("CreateCompositeRegions")]
public static void CreateCompositeRegions()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create two in memory circles
        using (Circle acCirc1 = new Circle())
            acCirc1.Center = new Point3d(4, 4, 0);
            acCirc1.Radius = 2;
            using (Circle acCirc2 = new Circle())
                acCirc2.Center = new Point3d(4, 4, 0);
                acCirc2.Radius = 1;
                // Adds the circle to an object array
                DBObjectCollection acDBObjColl = new DBObjectCollection();
                acDBObjColl.Add(acCirc1);
                acDBObjColl.Add(acCirc2);
                // Calculate the regions based on each closed loop
                DBObjectCollection myRegionColl = new DBObjectCollection();
                myRegionColl = Region.CreateFromCurves(acDBObjColl);
                Region acRegion1 = myRegionColl[0] as Region;
                Region acRegion2 = myRegionColl[1] as Region;
                // Subtract region 1 from region 2
                if (acRegion1.Area > acRegion2.Area)
                    // Subtract the smaller region from the larger one
                    acRegion1.BooleanOperation(BooleanOperationType.BoolSubtract, acRegion2);
                    acRegion2.Dispose();
                    // Add the final region to the database
                    acBlkTblRec.AppendEntity(acRegion1);
                    acTrans.AddNewlyCreatedDBObject(acRegion1, true);
                else
                    acRegion2.BooleanOperation(BooleanOperationType.BoolSubtract, acRegion1);
                    acRegion1.Dispose();
                    acBlkTblRec.AppendEntity(acRegion2);
                    acTrans.AddNewlyCreatedDBObject(acRegion2, true);
                // Dispose of the in memory objects not appended to the database
        // Save the new object to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
    ' Create two circles, one representing outside of the wheel,
    ' the other the center of the wheel
    Dim DonutParts(0 To 1) As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 4
    center(1) = 4
    center(2) = 0
    radius = 2#
    Set WheelParts(0) = ThisDrawing.ModelSpace. _
                            AddCircle(center, radius)
    radius = 1#
    Set WheelParts(1) = ThisDrawing.ModelSpace. _
    ' Create a region from the two circles
    Dim regions As Variant
    regions = ThisDrawing.ModelSpace.AddRegion(WheelParts)
    ' Copy the regions into the region variables for ease of use
    Dim WheelOuter As AcadRegion
    Dim WheelInner As AcadRegion
    If regions(0).Area > regions(1).Area Then
        ' The first region is the outer edge of the wheel
        Set WheelOuter = regions(0)
        Set WheelInner = regions(1)
    Else
        ' The first region is the inner edge of the wheel
        Set WheelInner = regions(0)
        Set WheelOuter = regions(1)
    End If
    ' Subtract the smaller circle from the larger circle
    WheelOuter.Boolean acSubtraction, WheelInner
GMT+8, 2026-10-28 01:11
