ObjectARX 开发指南
创建圆形对象 (.NET)
2023-1-1 14:58| 发布者: admin| 查看: 1812| 评论: 0|来自: AutoCAD
本示例在模型空间中创建一个中心点为 (2,3,0) 且半径为 4.25 的圆。
VB.NET
<CommandMethod("AddCircle")> _
Public Sub AddCircle()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a circle that is at 2,3 with a radius of 4.25
        Using acCirc As Circle = New Circle()
            acCirc.Center = New Point3d(2, 3, 0)
            acCirc.Radius = 4.25
            acBlkTblRec.AppendEntity(acCirc)
            acTrans.AddNewlyCreatedDBObject(acCirc, True)
        End Using
        '' Save the new object to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("AddCircle")]
public static void AddCircle()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a circle that is at 2,3 with a radius of 4.25
        using (Circle acCirc = new Circle())
            acCirc.Center = new Point3d(2, 3, 0);
            acCirc.Radius = 4.25;
            acBlkTblRec.AppendEntity(acCirc);
            acTrans.AddNewlyCreatedDBObject(acCirc, true);
        // Save the new object to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub AddCircle()
    ' Define the center point
    Dim ptCen(0 To 2) As Double
    ptCen(0) = 2: ptCen(1) = 3: ptCen(2) = 0#
    ' Create a Circle object in model space
    Dim circObj As AcadCircle
    Set circObj = ThisDrawing.ModelSpace.AddCircle(ptCen, 4.25)
GMT+8, 2026-10-27 05:27
