本示例使用 2D 坐标 (2,4)、(4,2) 和 (6,4) 将一条具有两条直线段的轻量级折线添加到模型空间。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("AddLightweightPolyline")> _
Public Sub AddLightweightPolyline()
'' Start a transaction
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a polyline with two segments (3 points)
Using acPoly As Polyline = New Polyline()
acPoly.AddVertexAt(0, New Point2d(2, 4), 0, 0, 0)
acPoly.AddVertexAt(1, New Point2d(4, 2), 0, 0, 0)
acPoly.AddVertexAt(2, New Point2d(6, 4), 0, 0, 0)
acBlkTblRec.AppendEntity(acPoly)
acTrans.AddNewlyCreatedDBObject(acPoly, True)
End Using
'' Save the new object to the database
acTrans.Commit()
End Using
[CommandMethod("AddLightweightPolyline")]
public static void AddLightweightPolyline()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a polyline with two segments (3 points)
using (Polyline acPoly = new Polyline())
acPoly.AddVertexAt(0, new Point2d(2, 4), 0, 0, 0);
acPoly.AddVertexAt(1, new Point2d(4, 2), 0, 0, 0);
acPoly.AddVertexAt(2, new Point2d(6, 4), 0, 0, 0);
acBlkTblRec.AppendEntity(acPoly);
acTrans.AddNewlyCreatedDBObject(acPoly, true);
// Save the new object to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub AddLightWeightPolyline()
Dim points(0 To 5) As Double
' Define the 2D polyline points
points(0) = 2: points(1) = 4
points(2) = 4: points(3) = 2
points(4) = 6: points(5) = 4
' Create a light weight Polyline object in model space
Set plineObj = ThisDrawing.ModelSpace. _
AddLightWeightPolyline(points)
相关概念父主题: |
GMT+8, 2026-10-28 05:26
