关于沿矢量移动对象 (VBA/ActiveX)
2024-5-18 16:52| 发布者: admin| 查看: 965| 评论: 0|原作者: admin|来自: AutoCAD
可以沿指定矢量移动所有图形对象和属性参照对象。
若要移动对象,请使用为该对象提供的方法。此方法需要两个坐标作为输入。这些坐标定义了一个位移矢量,指示给定对象要移动多远以及移动方向。Move
沿矢量移动圆圈
本示例创建一个圆,然后沿 X 轴移动该圆两个单位。
Sub Ch4_MoveCircle()
  ' Create the circle
  Dim circleObj As AcadCircle
  Dim center(0 To 2) As Double
  Dim radius As Double
  center(0) = 2#: center(1) = 2#: center(2) = 0#
  radius = 0.5
  Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
  ZoomAll
  ' Define the points that make up the move vector.
  ' The move vector will move the circle 2 units
  ' along the x axis.
  Dim point1(0 To 2) As Double
  Dim point2(0 To 2) As Double
  point1(0) = 0: point1(1) = 0: point1(2) = 0
  point2(0) = 2: point2(1) = 0: point2(2) = 0
  ' Move the circle
  circleObj.Move point1, point2
  circleObj.Update
GMT+8, 2026-11-3 23:12
