ObjectARX 开发指南
创建线条对象 (.NET)
2023-1-1 15:03| 发布者: admin| 查看: 2125| 评论: 0|来自: AutoCAD
本示例将一条从 (5,5,0) 开始,到 (12,3,0) 结束的线添加到模型空间。
VB.NET
<CommandMethod("AddLine")> _
Public Sub AddLine()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a line that starts at 5,5 and ends at 12,3
        Using acLine As Line = New Line(New Point3d(5, 5, 0), _
                                        New Point3d(12, 3, 0))
            acBlkTblRec.AppendEntity(acLine)
            acTrans.AddNewlyCreatedDBObject(acLine, True)
        End Using
        '' Save the new object to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("AddLine")]
public static void AddLine()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a line that starts at 5,5 and ends at 12,3
        using (Line acLine = new Line(new Point3d(5, 5, 0),
                                      new Point3d(12, 3, 0)))
            acBlkTblRec.AppendEntity(acLine);
            acTrans.AddNewlyCreatedDBObject(acLine, true);
        // Save the new object to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub AddLine()
    ' Define the start point
    Dim ptStr(0 To 2) As Double
    ptStr(0) = 5: ptStr(1) = 5: ptStr(2) = 0#
    ' Define the end point
    Dim ptEnd(0 To 2) As Double
    ptEnd(0) = 12: ptEnd(1) = 3: ptEnd(2) = 0#
    ' Create a Line object in model space
    Dim lineObj As AcadLine
    Set lineObj = ThisDrawing.ModelSpace.AddLine(ptStr, ptEnd)
相关概念
  1. 创建行 (.NET)
  1. 创建行 (.NET)
GMT+8, 2026-10-27 05:26
