关于创建复合区域 (VBA/ActiveX)
2024-5-18 16:52| 发布者: admin| 查看: 821| 评论: 0|原作者: admin|来自: AutoCAD
您可以通过减去、合并或查找区域或 3D 实体的交点来创建复合区域。
然后,可以拉伸或旋转复合区域以创建复杂的实体。若要创建复合区域,请使用以下方法。Boolean
当您从一个区域中减去另一个区域时,您可以从第一个区域调用该方法。这是要从中减去的区域。例如,若要计算楼层平面图需要多少地毯,请从楼层空间的外部边界调用该方法,并将未铺设地毯的区域(如柱子和柜台)用作布尔参数列表中的对象。BooleanBoolean
对区域执行的操作由 Boolean 方法的 BooleanType 参数确定。BooleanType 参数可以是下列参数之一:
  • acIntersection- 执行交叉路口操作。
  • acSubtraction- 执行减法运算。
  • acUnion- 执行联合操作。
创建复合区域
Sub Ch4_CreateCompositeRegions()
  ' Create two circles, one representing a room,
  ' the other a pillar in the center of the room
  Dim RoomObjects(0 To 1) As AcadCircle
  Dim center(0 To 2) As Double
  Dim radius As Double
  center(0) = 4
  center(1) = 4
  center(2) = 0
  radius = 2#
  Set RoomObjects(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
  radius = 1#
  Set RoomObjects(1) = ThisDrawing.ModelSpace.AddCircle(center, radius)
  ' Create a region from the two circles
  Dim regions As Variant
  regions = ThisDrawing.ModelSpace.AddRegion(RoomObjects)
  ' Copy the regions into the region variables for ease of use
  Dim RoundRoomObj As AcadRegion
  Dim PillarObj As AcadRegion
  If regions(0).Area > regions(1).Area Then
    ' The first region is the room
    Set RoundRoomObj = regions(0)
    Set PillarObj = regions(1)
  Else
    ' The first region is the pillar
    Set PillarObj = regions(0)
    Set RoundRoomObj = regions(1)
  End If
  ' Subtract the pillar space from the floor space to
  ' get a region that represents the total carpet area.
  RoundRoomObj.Boolean acSubtraction, PillarObj
  ' Use the Area property to determine the total carpet area
  MsgBox "The carpet area is: " & RoundRoomObj.Area
查找具有属性的结果区域的区域。Area
GMT+8, 2026-10-27 04:31
