关于控制用户输入 (VBA/ActiveX)
您可以使用该方法定义关键字或将输入类型限制为用户输入法。InitializeUserInput use 和参数值类似于 AutoLISP 函数。 可以与以下方法一起使用:、、、和。 不能与该方法一起使用。当用户输入法未返回字符串值时,使用该方法检索字符串值(关键字或任意输入)。initgetInitializeUserInputGetAngleGetCornerGetDistanceGetIntegerGetKeywordGetOrientationGetPointGetRealInitializeUserInputGetStringGetInput 该方法接受两个参数。第一个参数是位编码整数值,用于确定用户输入法的输入选项。第二个参数是定义有效关键字的字符串。InitializeUserInput 在AutoCAD命令提示符下从用户处获取整数值或关键字以下示例提示用户输入正数、非负整数值或关键字: Sub Ch3_UserInput()
' The first parameter of InitializeUserInput (6)
' restricts input to positive and non-negative
' values. The second parameter is the list of
' valid keywords.
ThisDrawing.Utility.InitializeUserInput 6, "Big Small Regular"
' Set the prompt string variable
Dim promptStr As String
promptStr = vbCrLf & "Enter the size or (Big/Small/<Regular>):"
' At the GetInteger prompt, entering a keyword or pressing
' ENTER without entering a value results in an error. To allow
' your application to continue and check for the error
' description, you must set the error handler to resume on error.
On Error Resume Next
' Get the value entered by the user
Dim returnInteger As Integer
returnInteger = ThisDrawing.Utility.GetInteger(promptStr)
' Check for an error. If the error number matches the
' one shown below, then use GetInput to get the returned
' string; otherwise, use the value of returnInteger.
If Err.Number = -2145320928 Then
Dim returnString As String
Debug.Print Err.Description
returnString = ThisDrawing.Utility.GetInput()
If returnString = "" Then 'ENTER returns null string
returnString = "Regular" 'Set to default
End If
Err.Clear
Else 'Otherwise,
returnString = returnInteger 'Use the value entered
End If
' Display the result
MsgBox returnString, , "InitializeUserInput Example"
GMT+8, 2026-10-27 01:22
