AutoCAD 2018 API 历史记录参考 (ActiveX)
2024-5-18 16:52| 发布者: admin| 查看: 675| 评论: 0|原作者: admin|来自: AutoCAD
对 AutoCAD 2018 和基于 AutoCAD 2018 的产品中的 ActiveX API 所做的添加和更改。
枚举
AcSaveAsType (Changed)
        ac2018_dwg = 64 (New)
        ac2018_dxf = 65 (New)
        ac2018_Template = 66 (New)
        acNative = 64 (Changed)
类
AcadAcCmColor
        Version number of the class has been incremented from 21 to 22; use the ProgID AutoCAD.AcCmColor.22.
AcadApplication
        Version number of the class has been incremented from 21 to 22; use the ProgID AutoCAD.Application.22.
        ProgID AutoCAD.Application.21 is now obsolete.
AcadLayerStateManager
        Version number of the class has been incremented from 21 to 22; use the ProgID AutoCAD.AcadLayerStateManager.22.
AcadSecurityParams
        Version number of the class has been incremented from 21 to 22; use the ProgID AutoCAD.SecurityParams.22.
IAcadDatabase (Changed)
        FileDependencies - Property (Obsolete)
IAcadFileDependencies (Obsolete)
        Application - Property
        Count - Property
        CreateEntry - Method
        IndexOf - Method
        Item - Method
        RemoveEntry - Method
        UpdateEntry - Method
IAcadFileDependency (Obsolete)
        AffectsGraphics - Property
        Feature - Property
        FileName - Property
        FileSize - Property
        FingerprintGuid - Property
        FoundPath - Property
        FullFileName - Property
        Index - Property
        IsModified - Property
        ReferenceCount - Property
        TimeStamp - Property
        VersionGuid - Property
GMT+8, 2026-10-27 04:56
