AutoCAD 2016 API 历史记录参考 (ActiveX)
对 AutoCAD 2016 和基于 AutoCAD 2016 的产品中的 ActiveX API 所做的添加和更改。 枚举AcSectionState2 (New)
acSectionState2Plane = 1
acSectionState2Slice = 2
acSectionState2Boundary = 4
acSectionState2Volume = 8
AcadSecurityParamsConstants (Obsolete)
ACADSECURITYPARAMS_ALGID_RC4 = 26625
AcadSecurityParamsType (Changed)
ACADSECURITYPARAMS_ENCRYPT_DATA = 1 (Obsolete)
ACADSECURITYPARAMS_ENCRYPT_PROPS = 2 (Obsolete)
类IAcadDocument (Changed)
SaveAs - Method (Support for adding password protection has been removed)
IAcadPointCloudEx (Changed)
Segmentation - Property (New)
IAcadSection (Changed)
SectionPlaneOffset - Property (New)
SliceDepth - Property (New)
State2 - Property (New)
IAcadSecurityParams (Changed)
Action - Property (Constants ACADSECURITYPARAMS_ENCRYPT_DATA and ACADSECURITYPARAMS_ENCRYPT_PROPS are no longer supported)
Algorithm - Property (Obsolete)
KeyLength - Property (Obsolete)
Password - Property (Obsolete)
ProviderName - Property (Obsolete)
ProviderType - Property (Obsolete)
IAcadShadowDisplay - Interface is only supported by the MentalRay renderer
相关概念 |
GMT+8, 2026-10-27 08:59
