AutoCAD 2015 API 历史记录参考 (ActiveX)
对 AutoCAD 2015 和基于 AutoCAD 2015 的产品中的 ActiveX API 所做的添加和更改。 枚举AcPointCloudExStylizationType (New)
acRGB = 0
acObject = 1
acNormals = 2
acIntensities = 3
acElevation = 4
acClassification = 5
类IAcadApplication
HWND32 - Property (Removed; use HWND)
IAcadDatabase
ObjectIDToObject32 - Method (Removed; use ObjectIDToObject)
IAcadDocument
PostCommand - Method (New)
IAcadGeomapImage (New)
GeoImageBrightness - Property
GeoImageContrast - Property
GeoImageFade - Property
GeoImagePosition - Property
GeoImageWidth - Property
GeoImageHeight - Property
IAcadIDPair
Key32 - Property (Removed; use Key)
Value32 - Property (Removed; use Value)
IAcadMLeader
GetBlockAttributeValue32 - Method (Removed; use GetBlockAttributeValue)
SetBlockAttributeValue32 - Method (Removed; use SetBlockAttributeValue)
IAcadObject
ObjectID32 - Property (Removed; use ObjectID)
OwnerID32 - Property (Removed; use OwnerID)
IAcadPointCloud (Changed)
Stylization - Property (Moved from IAcadPointCloud2)
Unit - Property (Moved from IAcadPointCloud2)
UnitFactor - Property (Moved from IAcadPointCloud2)
IAcadPointCloudEx (New)
ColorScheme - Property
Geolocate - Property
InsertionPoint - Property
Locked - Property
Name - Property
Path - Property
Rotation - Property
scale - Property
ShowCropped - Property
Unit - Property
IAcadPViewport
LabelBlockId32 - Property (Removed; use LabelBlockId)
IAcadTable
GetBlockAttributeValue232 - Method (Removed; use GetBlockAttributeValue2)
GetBlockTableRecordId232 - Method (Removed; use GetBlockTableRecordId2)
GetBlockTableRecordId32 - Method (Removed; use GetBlockTableRecordId)
GetFieldId232 - Method (Removed; use GetFieldId2)
GetFieldId32 - Method (Removed; use GetFieldId)
GetGridLinetype32 - Method (Removed; use GetGridLinetype)
SetBlockAttributeValue232 - Method (Removed; use SetBlockAttributeValue2)
SetBlockTableRecordId232 - Method (Removed; use SetBlockTableRecordId2)
SetBlockTableRecordId32 - Method (Removed; use SetBlockTableRecordId)
SetFieldId232 - Method (Removed; use SetFieldId2)
SetFieldId32 - Method (Removed; use SetFieldId)
SetGridLinetype32 - Method (Removed; use SetGridLinetype)
IAcadTableStyle
GetTextStyleId32 - Method (Removed; use GetTextStyleId)
SetTemplateId32 - Method (Removed; use SetTemplateId)
SetTextStyleId32 - Method (Removed; use SetTextStyleId)
TemplateId32 - Property (Removed; use TemplateId)
IAcadUtility
GetSubEntity32 - Method (Removed; use GetSubEntity)
ObjectId32ToObjectIdString - Method (Removed; use ObjectIdToObjectIdString)
IAcadView
LayoutID32 - Property (Removed; use LayoutID)
_DAcadDocumentEvents (Changed)
ObjectErased - Event (ObjectID must now be a Long)
WindowMovedOrResized - Event (HWNDFrame must now be a Long)
以下类已删除/与其父类合并: IAcadPointCloud2 - Removed (Moved to IAcadPointCloud) 相关概念 |
GMT+8, 2026-11-15 13:51
