AutoCAD 2014 API 历史记录参考 (ActiveX)
2024-5-18 16:52| 发布者: admin| 查看: 968| 评论: 0|原作者: admin|来自: AutoCAD
对 AutoCAD 2014 和基于 AutoCAD 2014 的产品中的 ActiveX API 所做的添加和更改。
枚举
AcPointCloudStylizationType (New)
        acIntensity = 3
        acNormal = 2
        acObjectColor = 1
        acScanColor = 0
类
IAcadApplication
        HWND32 - Property (Obsolete; use HWND)
IAcadDatabase
        ObjectIDToObject32 - Method (Obsolete; use ObjectIDToObject)
IAcadDocument
IAcadGeoPositionMarker (New)
        Altitude - Property
        BackgroundFill - Property
        DrawingDirection - Property
        Height - Property
        LandingGap - Property
        Latitude - Property
        LineSpacingDistance - Property
        LineSpacingFactor - Property
        LineSpacingStyle - Property
        Longitude - Property
        Notes - Property
        Position - Property
        Radius - Property
        Rotation - Property
        TextFrameDisplay - Property
        TextJustify - Property
        TextString - Property
        TextStyleName - Property
        TextWidth - Property
IAcadIDPair
        Key32 - Property (Obsolete; use Key)
        Value32 - Property (Obsolete; use Value)
IAcadMLeader
        GetBlockAttributeValue32 - Method (Obsolete; use GetBlockAttributeValue)
        SetBlockAttributeValue32 - Method (Obsolete; use SetBlockAttributeValue)
IAcadObject
        ObjectID32 - Property (Obsolete; use ObjectID)
        OwnerID32 - Property (Obsolete; use OwnerID)
IAcadPointCloud2 (New)
        Stylization - Property
        Unit - Property
        UnitFactor - Property
IAcadPViewport
        LabelBlockId32 - Property (Obsolete; use LabelBlockId)
IAcadTable
        GetBlockAttributeValue232 - Method (Obsolete; use GetBlockAttributeValue2)
        GetBlockTableRecordId232 - Method (Obsolete; use GetBlockTableRecordId2)
        GetBlockTableRecordId32 - Method (Obsolete; use GetBlockTableRecordId)
        GetFieldId232 - Method (Obsolete; use GetFieldId2)
        GetFieldId32 - Method (Obsolete; use GetFieldId)
        GetGridLinetype32 - Method (Obsolete; use GetGridLinetype)
        SetBlockAttributeValue232 - Method (Obsolete; use SetBlockAttributeValue2)
        SetBlockTableRecordId232 - Method (Obsolete; use SetBlockTableRecordId2)
        SetBlockTableRecordId32 - Method (Obsolete; use SetBlockTableRecordId)
        SetFieldId232 - Method (Obsolete; use SetFieldId2)
        SetFieldId32 - Method (Obsolete; use SetFieldId)
        SetGridLinetype32 - Method (Obsolete; use SetGridLinetype)
IAcadTableStyle
        GetTextStyleId32 - Method (Obsolete; use GetTextStyleId)
        SetTemplateId32 - Method (Obsolete; use SetTemplateId)
        SetTextStyleId32 - Method (Obsolete; use SetTextStyleId)
        TemplateId32 - Property (Obsolete; use TemplateId)
IAcadUtility
        GetSubEntity32 - Method (Obsolete; use GetSubEntity)
        ObjectId32ToObjectIdString - Method (Obsolete; use ObjectIdToObjectIdString)
IAcadView
        LayoutID32 - Property (Obsolete; use LayoutID)
GMT+8, 2026-10-27 09:13
