AutoCAD 2011 API 历史记录参考 (ActiveX)
2024-5-18 16:52| 发布者: admin| 查看: 636| 评论: 0|原作者: admin|来自: AutoCAD
对 AutoCAD 2011 和基于 AutoCAD 2011 的产品中的 ActiveX API 所做的添加和更改。
枚举
AcEntityName (Changed)
        acNurbSurface = 51 (New)
AcSaveAsType (Changed)
        ac2010_dwg = 48 (New)
        ac2010_dxf = 49 (New)
        ac2010_Template = 50 (New)
        acNative = 48 (Changed)
AcWireframeType (New)
        acIsolines = 0
        acIsoparms = 1
AcSplineKnotParameterizationType (New)
        acChord = 0
        acSqrtChord = 1
        acUniformParam = 2
        acCustomParameterization = 15
AcSplineFrameType (New)
        acShow = 0
        acHide = 1
AcSplineMethodType (New)
        acFit = 0
        acControlVertices = 1
AcPointCloudColorType (New)
        acByColor = 0
        acPreset = 1
类
IAcadEntity2 (New)
        EntityTransparency - Property
IAcadRasterImage2 (New)
IAcad3DFace2 (New)
IAcad3DPolyline2 (New)
IAcadRegion2 (New)
IAcad3DSolid2 (New)
IAcadArc2 (New)
IAcadAttribute2 (New)
IAcadBlockReference2 (New)
IAcadCircle2 (New)
IAcadEllipse2 (New)
IAcadHatch2 (New)
        BackgroundColor - Property
IAcadLeader2 (New)
IAcadMLeader2 (New)
IAcadLWPolyline2 (New)
IAcadLine2 (New)
IAcadMText2 (New)
IAcadPoint2 (New)
IAcadPolyline2 (New)
IAcadPolygonMesh2 (New)
IAcadRay2 (New)
IAcadShape2 (New)
IAcadSolid2 (New)
IAcadSpline2 (New)
        KnotParameterization - Property
        SplineFrame - Property
        SplineMethod - Property
        Degree2 - Property
        Closed2 - Property
IAcadText2 (New)
IAcadTolerance2 (New)
IAcadTrace2 (New)
IAcadXline2 (New)
IAcadPViewport2 (New)
IAcadPolyfaceMesh2 (New)
IAcadMLine2 (New)
IAcadExternalReference2 (New)
IAcadTable2 (New)
IAcadOle2 (New)
IAcadHelix2 (New)
IAcadSurface2 (New)
        WireframeType - Property
        MaintainAssociativity - Property
        ShowAssociativity - Property
        EdgeExtensionDistances - Property
IAcadPlaneSurface2 (New)
IAcadExtrudedSurface2 (New)
IAcadRevolvedSurface2 (New)
IAcadSweptSurface2 (New)
IAcadLoftedSurface2 (New)
        StartSmoothMagnitude - Property
        EndSmoothMagnitude - Property
        StartSmoothContinuity - Property
        EndSmoothContinuity - Property
        Periodic - Property
IAcadWipeout2 (New)
IAcadSubDMesh2 (New)
IAcadNurbSurface (New)
        CvHullDisplay - Property
IAcadDimAligned2 (New)
IAcadDimAngular2 (New)
IAcadDimDiametric2 (New)
IAcadDimOrdinate2 (New)
IAcadDimRadial2 (New)
IAcadDimRotated2 (New)
IAcadDim3PointAngular2 (New)
IAcadDimArcLength2 (New)
IAcadDimRadialLarge2 (New)
IAcadPointCloud (New)
        InsertionPoint - Property
        scale - Property
        Rotation - Property
        UseEntityColor - Property
        Locked - Property
GMT+8, 2026-10-27 09:46
