AutoCAD 2004 API 历史记录参考 (ActiveX)
对 AutoCAD 2004 和基于 AutoCAD 2004 的产品中的 ActiveX API 所做的添加和更改。 枚举AcViewportScale (Change)
acVp1and1_2in_1ft = 30 (Changed)
acVp3in_1ft = 31 (Changed)
acVp6in_1ft = 32 (Changed)
acVp1ft_1ft = 33 (New)
AcSaveAsType (Changed)
ac2000_dwg = 12 (New)
ac2000_dxf = 13 (New)
ac2000_Template = 14 (New)
ac2004_dwg = 24 (New)
ac2004_dxf = 25 (New)
ac2004_Template = 26 (New)
acNative = 24 (Changed)
acR18_dwg = 24 (New)
acR18_dxf = 25 (New)
acR18_Template = 26 (New)
AcShadePlot (New)
acShadePlotAsDisplayed = 0
acShadePlotWireframe = 1
acShadePlotHidden = 2
acShadePlotRendered = 3
AcHatchObjectType (New)
acHatchObject = 0
acGradientObject = 1
AcGradientPatternType (New)
acPreDefinedGradient = 0
acUserDefinedGradient = 1
AcColorMethod (New)
acColorMethodByLayer = 192
acColorMethodByBlock = 193
acColorMethodByRGB = 194
acColorMethodByACI = 195
acColorMethodForeground = 197
AcadSecurityParamsType (New)
ACADSECURITYPARAMS_ENCRYPT_DATA = 1
ACADSECURITYPARAMS_ENCRYPT_PROPS = 2
ACADSECURITYPARAMS_SIGN_DATA = 16
ACADSECURITYPARAMS_ADD_TIMESTAMP = 32
AcadSecurityParamsConstants (New)
ACADSECURITYPARAMS_ALGID_RC4 = 26625
类IAcadDatabase (Changed)
FileDependencies - Property (New)
SummaryInfo - Property (New)
IAcadBlock (Changed)
InsertBlock - Method (Changed - Password parameter)
AddHatch - Method (Changed - Hatch object type parameter)
AddMInsertBlock - Method (Changed - Password parameter)
AttachExternalReference - Method (Changed - Password parameter)
IAcadEntity (Changed)
TrueColor - Property (New)
IAcadAcCmColor (New)
EntityColor - Property
ColorName - Property
BookName - Property
SetNames - Method
Delete - Method
Red - Property
Blue - Property
Green - Property
SetRGB - Method
ColorMethod - Property
ColorIndex - Property
SetColorBookColor - Method
IAcad3DPolyline (Changed)
Length - Property (New)
IAcadDimension (Changed)
TextColor - Property (New)
IAcadMText (Changed)
LineSpacingDistance - Property (New)
IAcadLWPolyline (Changed)
IAcadPolyline (Changed)
IAcadTolerance (Changed)
IAcadHatch (Changed)
GradientColor1 - Property (New)
GradientColor2 - Property (New)
GradientAngle - Property (New)
GradientCentered - Property (New)
GradientName - Property (New)
HatchObjectType - Property (New)
IAcadPViewport (Changed)
RemoveHiddenLines - Property (Hidden)
ShadePlot - Property (New)
IAcadGroup (Changed)
color - Property (Hidden)
IAcadLayer
IAcadFileDependencies (New)
Item - Method
Application - Property
Count - Property
CreateEntry - Method
IndexOf - Method
RemoveEntry - Method
UpdateEntry - Method
IAcadFileDependency (New)
FullFileName - Property
FileName - Property
FoundPath - Property
FingerprintGuid - Property
VersionGuid - Property
Feature - Property
IsModified - Property
AffectsGraphics - Property
Index - Property
TimeStamp - Property
FileSize - Property
ReferenceCount - Property
IAcadSummaryInfo (New)
Author - Property
Comments - Property
HyperlinkBase - Property
Keywords - Property
LastSavedBy - Property
RevisionNumber - Property
Subject - Property
Title - Property
NumCustomInfo - Method
GetCustomByIndex - Method
GetCustomByKey - Method
SetCustomByIndex - Method
SetCustomByKey - Method
AddCustomInfo - Method
RemoveCustomByIndex - Method
RemoveCustomByKey - Method
IAcadSecurityParams (New)
Action - Property
Password - Property
ProviderType - Property
ProviderName - Property
Algorithm - Property
KeyLength - Property
Subject - Property
Issuer - Property
SerialNumber - Property
Comment - Property
TimeServer - Property
IAcadDocument (Changed)
Open - Method (Changed - Password parameter)
SaveAs - Method (Changed - Password parameter)
IAcadApplication (Changed)
HWND - Property (New)
IAcadPreferencesFiles (Changed)
LicenseServer - Property (Changed to hidden)
ObjectARXPath - Property (Changed to hidden)
ColorBookPath - Property (New)
ToolPalettePath - Property (New)
IAcadPreferencesUser (Changed)
SCMTimeMode - Property (New)
SCMTimeValue - Property (New)
IAcadDocuments (Changed)
相关概念 |
GMT+8, 2026-11-15 12:46
