在收集用户的输入时,您需要确保限制他们可以输入的信息类型,以便获得所需的响应。各种提示选项对象不仅用于定义命令提示符下显示的提示,还用于限制用户可以提供的输入。使用某些输入法,您不仅可以根据所使用的方法类型获得返回值,还可以获得关键字。 例如,可以使用该方法让用户指定一个点或使用关键字进行响应。这就是 LINE、CIRCLE 和 PLINE 等命令的工作方式。GetPoint 获取整数值或关键字以下示例提示用户输入正非零整数值或关键字。 VB.NETImports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("GetIntegerOrKeywordFromUser")> _
Public Sub GetIntegerOrKeywordFromUser()
Dim pIntOpts As PromptIntegerOptions = New PromptIntegerOptions("")
pIntOpts.Message = vbCrLf & "Enter the size or "
'' Restrict input to positive and non-negative values
pIntOpts.AllowZero = False
pIntOpts.AllowNegative = False
'' Define the valid keywords and allow Enter
pIntOpts.Keywords.Add("Big")
pIntOpts.Keywords.Add("Small")
pIntOpts.Keywords.Add("Regular")
pIntOpts.Keywords.Default = "Regular"
pIntOpts.AllowNone = True
'' Get the value entered by the user
Dim pIntRes As PromptIntegerResult = acDoc.Editor.GetInteger(pIntOpts)
If pIntRes.Status = PromptStatus.Keyword Then
Application.ShowAlertDialog("Entered keyword: " & _
pIntRes.StringResult)
Else
Application.ShowAlertDialog("Entered value: " & _
pIntRes.Value.ToString())
End If
C#using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("GetIntegerOrKeywordFromUser")]
public static void GetIntegerOrKeywordFromUser()
PromptIntegerOptions pIntOpts = new PromptIntegerOptions("");
pIntOpts.Message = "\nEnter the size or ";
// Restrict input to positive and non-negative values
pIntOpts.AllowZero = false;
pIntOpts.AllowNegative = false;
// Define the valid keywords and allow Enter
pIntOpts.Keywords.Add("Big");
pIntOpts.Keywords.Add("Small");
pIntOpts.Keywords.Add("Regular");
pIntOpts.Keywords.Default = "Regular";
pIntOpts.AllowNone = true;
// Get the value entered by the user
PromptIntegerResult pIntRes = acDoc.Editor.GetInteger(pIntOpts);
if (pIntRes.Status == PromptStatus.Keyword)
Application.ShowAlertDialog("Entered keyword: " +
pIntRes.StringResult);
else
Application.ShowAlertDialog("Entered value: " +
pIntRes.Value.ToString());
VBA/ActiveX 代码参考Sub GetIntegerOrKeywordFromUser()
' The first parameter of InitializeUserInput (6)
' restricts input to positive and non-negative
' values. The second parameter is the list of
' valid keywords.
ThisDrawing.Utility.InitializeUserInput 6, "Big Small Regular"
' Set the prompt string variable
Dim promptStr As String
promptStr = vbCrLf & "Enter the size or [Big/Small/Regular] <Regular>:"
' At the GetInteger prompt, entering a keyword or pressing
' ENTER without entering a value results in an error. To allow
' your application to continue and check for the error
' description, you must set the error handler to resume on error.
On Error Resume Next
Dim returnInteger As Integer
returnInteger = ThisDrawing.Utility.GetInteger(promptStr)
' Check for an error. If the error number matches the
' one shown below, then use GetInput to get the returned
' string; otherwise, use the value of returnInteger.
If Err.Number = -2145320928 Then
Dim returnString As String
Debug.Print Err.Description
returnString = ThisDrawing.Utility.GetInput()
If returnString = "" Then 'ENTER returns null string
returnString = "Regular" 'Set to default
End If
Err.Clear
Else 'Otherwise,
returnString = returnInteger 'Use the value entered
End If
' Display the result
MsgBox returnString, , "InitializeUserInput Example"
相关概念父主题: |
GMT+8, 2026-10-28 07:25
