该方法提示用户在命令提示符下指定一个点。该对象允许您控制输入的输入以及提示消息的显示方式。对象的 和 属性控制是否从基点绘制橡皮筋线。该对象的属性允许您定义除了指定点之外还可以在命令提示符下输入的关键字。GetPointPromptPointOptionsUseBasePointBasePointPromptPointOptionsKeywordsPromptPointOptions 获取用户选择的点下面的示例提示用户输入两个点,然后使用这些点作为起点和终结点绘制一条线。 VB.NETImports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("GetPointsFromUser")> _
Public Sub GetPointsFromUser()
'' Get the current database and start the Transaction Manager
Dim pPtRes As PromptPointResult
Dim pPtOpts As PromptPointOptions = New PromptPointOptions("")
'' Prompt for the start point
pPtOpts.Message = vbLf & "Enter the start point of the line: "
pPtRes = acDoc.Editor.GetPoint(pPtOpts)
Dim ptStart As Point3d = pPtRes.Value
'' Exit if the user presses ESC or cancels the command
If pPtRes.Status = PromptStatus.Cancel Then Exit Sub
'' Prompt for the end point
pPtOpts.Message = vbLf & "Enter the end point of the line: "
pPtOpts.UseBasePoint = True
pPtOpts.BasePoint = ptStart
Dim ptEnd As Point3d = pPtRes.Value
'' Start a transaction
Dim acBlkTbl As BlockTable
'' Open Model space for write
OpenMode.ForRead)
OpenMode.ForWrite)
'' Define the new line
Using acLine As Line = New Line(ptStart, ptEnd)
'' Add the line to the drawing
acBlkTblRec.AppendEntity(acLine)
acTrans.AddNewlyCreatedDBObject(acLine, True)
End Using
'' Zoom to the extents or limits of the drawing
acDoc.SendStringToExecute("._zoom _all ", True, False, False)
'' Commit the changes and dispose of the transaction
acTrans.Commit()
End Using
C#using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("GetPointsFromUser")]
public static void GetPointsFromUser()
// Get the current database and start the Transaction Manager
PromptPointResult pPtRes;
PromptPointOptions pPtOpts = new PromptPointOptions("");
// Prompt for the start point
pPtOpts.Message = "\nEnter the start point of the line: ";
pPtRes = acDoc.Editor.GetPoint(pPtOpts);
Point3d ptStart = pPtRes.Value;
// Exit if the user presses ESC or cancels the command
if (pPtRes.Status == PromptStatus.Cancel) return;
// Prompt for the end point
pPtOpts.Message = "\nEnter the end point of the line: ";
pPtOpts.UseBasePoint = true;
pPtOpts.BasePoint = ptStart;
Point3d ptEnd = pPtRes.Value;
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Open Model space for write
// Define the new line
using (Line acLine = new Line(ptStart, ptEnd))
// Add the line to the drawing
acBlkTblRec.AppendEntity(acLine);
acTrans.AddNewlyCreatedDBObject(acLine, true);
// Zoom to the extents or limits of the drawing
acDoc.SendStringToExecute("._zoom _all ", true, false, false);
// Commit the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub GetPointsFromUser()
Dim startPnt As Variant
Dim endPnt As Variant
Dim prompt1 As String
Dim prompt2 As String
prompt1 = vbCrLf & "Enter the start point of the line: "
prompt2 = vbCrLf & "Enter the end point of the line: "
' Get the first point without entering a base point
startPnt = ThisDrawing.Utility.GetPoint(, prompt1)
' Use the point entered above as the base point
endPnt = ThisDrawing.Utility.GetPoint(startPnt, prompt2)
' Create a line using the two points entered
ThisDrawing.ModelSpace.AddLine startPnt, endPnt
相关概念父主题: |
GMT+8, 2026-10-26 18:02
