查看代码 (AutoLISP)
2024-5-18 16:52| 发布者: admin| 查看: 630| 评论: 0|原作者: admin|来自: AutoCAD
查看代码 (AutoLISP)
现在看一下该函数的代码:gp:calculate-Draw-TileRow
(defun gp:calculate-Draw-TileRow (startPoint TileRadius
                                  TileSpace pathWidth pathAngle offsetFromCenter
                                  ObjectCreationStyle / HalfWidth TileDiameter
                                  ObjectCreationFunction angp90 angm90
                                  firstCenterPt TileCenterPt TileList)
  (setq HalfWidth (- (/ pathWidth 2.00) TileRadius)
     Tilespacing (+ (* TileRadius 2.0) TileSpace)
     TileDiameter (* TileRadius 2.0)
     angp90 (+ PathAngle (Degrees->Radians 90))
     angm90 (- PathAngle (Degrees->Radians 90))
     firstCenterPt (polar startPoint angp90 offsetFromCenter)
     tileCenterPt firstCenterPt
     ObjectCreationStyle(strcase ObjectCreationStyle)
     (cond
          ((equal ObjectCreationStyle "ACTIVEX")
            gp:Create_activeX_Circle
          ((equal ObjectCreationStyle "ENTMAKE")
            gp:Create_entmake_Circle
          ((equal ObjectCreationStyle "COMMAND")
            gp:Create_command_Circle
          (T
            (alert (strcat "ObjectCreationStyle in function
                   gp:calculate-Draw-TileRow"
                  "\nis invalid. Contact developer for assistance."
                  "\n        ObjectCreationStyle set to ACTIVEX"
             setq ObjectCreationStyle "ACTIVEX")
       ;; Draw the circles to the left of the center.
       (while (< (distance startPoint tileCenterPt) HalfWidth)
         ;; Add each tile to the list to return.
        (setq tileList
             (cons
             (ObjectCreationFunction tileCenterPt TileRadius)
                   tileList
        ;; Calculate the center point for the next tile.
        (setq tileCenterPt
          (polar tileCenterPt angp90 TileSpacing)
       );_ end of while
       ;; Draw the circles to the right of the center.
       (setq tileCenterPt
         (polar firstCenterPt angm90 TileSpacing))
          (setq tileList
               (cons
                    tileList
         (setq tileCenterPt (polar tileCenterPt angm90 TileSpacing))
       );_ end of while
       ;; Return the list of tiles.
       tileList
) ;_ end of defun
AutoLISP 代码逻辑遵循伪代码,并添加了以下内容:
(setq ObjectCreationFunction
  (cond
     (T
       (alert
         (strcat
          "ObjectCreationStyle in function gp:calculate-Draw-TileRow"
          "\nis invalid.  Contact the developer for assistance."
         ) ;_ end of strcat
       ) ;_ end of alert
      (setq ObjectCreationStyle "ACTIVEX")
  ) ;_ end of cond
) ;_ end of setq
还记得允许用户使用 ActiveX、函数或函数绘制图块(圆圈)的规范吗?变量被分配三个函数之一,具体取决于参数(从和通过传递)。下面是将在 gpdraw.lsp 中定义的三个函数:entmakecommandObjectCreationFunctionObjectCreationStyle C:GPath gp:Calculate-and-Draw-Tiles
(defun gp:Create_activeX_Circle (center radius)
  (vla-addCircle *ModelSpace*
    (vlax-3d-point center) ; convert to ActiveX-compatible 3D point
    radius
) ;_ end of defun
(defun gp:Create_entmake_Circle	(center radius)
  (entmake
    (list (cons 0 "CIRCLE") (cons 10 center) (cons 40 radius))
  (vlax-ename->vla-object (entlast))
(defun gp:Create_command_Circle	(center radius)
  (command "._circle" center radius)
第一个函数使用 ActiveX 函数绘制一个圆,并返回一个 ActiveX 对象。
第二个函数使用 绘制一个圆。它返回转换为 ActiveX 对象的实体名称。entmake
第三个函数使用 绘制一个圆。它还返回转换为 ActiveX 对象的实体名称。command
GMT+8, 2026-10-27 05:24
