连续绘制图块
2024-5-18 16:52| 发布者: admin| 查看: 1001| 评论: 0|原作者: admin|来自: AutoCAD
连续绘制图块
现在你已经有了绘制路径的逻辑,下一步就是弄清楚如何在每一行中绘制图块。在下图中,显示了两种情况:一行与路径中心的偏移量等于 0.0,另一行的偏移量不等于零。请看一下图表,然后阅读下面的伪代码。
Set up variables for StartPoint, angp90, angm90, and so on.
Set the variable FirstCenterPoint to the StartPoint + offset amount
    (which may be 0.0).
Set the initial value of TileCenterPt to FirstCenterPoint.
(Comment: Begin by drawing the circles in the angp90 direction.)
While the distance from the StartPoint to the TileCenterPt is less than the HalfWidth:
    Draw a circle (adding to the accumulating list of circles).
    Set TileCenterPt to the next tile space increment in the angp90
    direction.
End While
Reset the TileCenterPoint to the FirstCenterPoint + the tile space increment at angm90.
    Set TileCenterPt to the next tile space increment in the angm90
    direction.
End While
Return the list of circles.
GMT+8, 2026-10-27 11:07
