可以使用在成员对象上找到的方法擦除集合对象中的成员。例如,以下代码从对象中删除层 MyLayer。EraseLayerTable 在从图形中擦除图层之前,应确保可以安全地将其移除。要确定是否可以擦除图层或其他命名对象(如块或文本样式),应使用该方法。Purge VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("RemoveMyLayer")> _
Public Sub RemoveMyLayer()
'' Get the current document and database, and start a transaction
'' Returns the layer table for the current database
Dim acLyrTbl As LayerTable
acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
OpenMode.ForRead)
'' Check to see if MyLayer exists in the Layer table
If acLyrTbl.Has("MyLayer") = True Then
Dim acLyrTblRec As LayerTableRecord
acLyrTblRec = acTrans.GetObject(acLyrTbl("MyLayer"), _
OpenMode.ForWrite)
Try
acLyrTblRec.Erase()
acDoc.Editor.WriteMessage(vbLf & "'MyLayer' was erased")
'' Commit the changes
acTrans.Commit()
Catch
acDoc.Editor.WriteMessage(vbLf & "'MyLayer' could not be erased")
End Try
Else
acDoc.Editor.WriteMessage(vbLf & "'MyLayer' does not exist")
End If
'' Dispose of the transaction
End Using
[CommandMethod("RemoveMyLayer")]
public static void RemoveMyLayer()
// Get the current document and database, and start a transaction
// Returns the layer table for the current database
LayerTable acLyrTbl;
OpenMode.ForRead) as LayerTable;
// Check to see if MyLayer exists in the Layer table
if (acLyrTbl.Has("MyLayer") == true)
LayerTableRecord acLyrTblRec;
acLyrTblRec = acTrans.GetObject(acLyrTbl["MyLayer"],
OpenMode.ForWrite) as LayerTableRecord;
try
acLyrTblRec.Erase();
acDoc.Editor.WriteMessage("\n'MyLayer' was erased");
// Commit the changes
acTrans.Commit();
catch
acDoc.Editor.WriteMessage("\n'MyLayer' could not be erased");
else
acDoc.Editor.WriteMessage("\n'MyLayer' does not exist");
// Dispose of the transaction
VBA/ActiveX 代码参考Sub RemoveMyLayer()
On Error Resume Next
'' Get the layer "MyLayer" from the Layers collection
Dim ABCLayer As AcadLayer
Set ABCLayer = ThisDrawing.Layers.Item("MyLayer")
'' Check for an error, if no error occurs the layer exists
If Err = 0 Then
'' Delete the layer
ABCLayer.Delete
'' Clear the current error
Err.Clear
'' Get the layer again if it is found the layer could not be removed
'' Check for error, if an error is encountered the layer was removed
If Err <> 0 Then
ThisDrawing.Utility.prompt "'MyLayer' was removed"
Else
ThisDrawing.Utility.prompt "'MyLayer' could not be removed"
End If
Else
ThisDrawing.Utility.prompt "'MyLayer' does not exist"
End If
擦除对象后,不应在程序后期再次尝试访问该对象;否则将发生错误。上面的示例在再次访问对象之前测试该对象是否存在。当发出擦除对象的请求时,应检查该方法是否存在该对象,或者使用语句捕获发生的任何异常。HasTry 父主题: |
GMT+8, 2026-11-1 17:42
