若要向集合中添加新成员,请使用该方法。例如,以下代码创建一个新图层并将其添加到“图层”表中:Add VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("AddMyLayer")> _
Public Sub AddMyLayer()
'' Get the current document and database, and start a transaction
'' Returns the layer table for the current database
Dim acLyrTbl As LayerTable
acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
OpenMode.ForRead)
'' Check to see if MyLayer exists in the Layer table
If Not acLyrTbl.Has("MyLayer") Then
'' Open the Layer Table for write
acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite)
'' Create a new layer table record and name the layer "MyLayer"
Using acLyrTblRec As LayerTableRecord = New LayerTableRecord
acLyrTblRec.Name = "MyLayer"
'' Add the new layer table record to the layer table and the transaction
acLyrTbl.Add(acLyrTblRec)
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
End Using
'' Commit the changes
acTrans.Commit()
End If
'' Dispose of the transaction
End Using
[CommandMethod("AddMyLayer")]
public static void AddMyLayer()
// Get the current document and database, and start a transaction
// Returns the layer table for the current database
LayerTable acLyrTbl;
OpenMode.ForRead) as LayerTable;
// Check to see if MyLayer exists in the Layer table
if (acLyrTbl.Has("MyLayer") != true)
// Open the Layer Table for write
acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite);
// Create a new layer table record and name the layer "MyLayer"
using (LayerTableRecord acLyrTblRec = new LayerTableRecord())
acLyrTblRec.Name = "MyLayer";
// Add the new layer table record to the layer table and the transaction
acLyrTbl.Add(acLyrTblRec);
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, true);
// Commit the changes
acTrans.Commit();
// Dispose of the transaction
VBA/ActiveX 代码参考Sub AddMyLayer()
Dim newLayer as AcadLayer
Set newLayer = ThisDrawing.Layers.Add("MyLayer")
相关概念父主题: |
GMT+8, 2026-10-30 05:00
