关于列出对象的属性和方法 (AutoLISP/ActiveX)
2024-5-18 16:50| 发布者: admin| 查看: 1070| 评论: 0|原作者: admin|来自: AutoCAD
Visual LISP Inspect 工具和函数允许您显示对象的属性。vlax-dump-object
可以从 AutoLISP 程序、Visual LISP 控制台窗口提示符或 AutoCAD 命令提示符调用该函数。该函数打印指定对象的属性列表并返回 。vlax-dump-objectvlax-dump-objectT
例如,以下代码获取添加到模型空间的最后一个对象,然后发出打印对象属性的问题:vlax-dump-object
(setq WhatsMyLine (vla-item mSpace (- (vla-get-count mspace) 1)))
#<VLA-OBJECT IAcadLWPolyline 036f1d0c>
(vlax-dump-object WhatsMyLine)
; IAcadLWPolyline: AutoCAD Lightweight Polyline Interface
; Property values:
; Application (RO) = #<VLA-OBJECT IAcadApplication 00a4ae24>
; Area (RO) = 2.46556
; Closed = 0
; Color = 256
; ConstantWidth = 0.0
; Coordinate = ...Indexed contents not shown...
; Coordinates = (8.49917 7.00155 11.2996 3.73137 14.8 5.74379 ... )
; Database (RO) = #<VLA-OBJECT IAcadDatabase 01e3da44>
; Elevation = 0.0
; Handle (RO) = "53"
; HasExtensionDictionary (RO) = 0
; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 01e3d7d4>
; Layer = "0"
; Linetype = "BYLAYER"
; LinetypeGeneration = 0
; LinetypeScale = 1.0
; Lineweight = -1
; Normal = (0.0 0.0 1.0)
; ObjectID (RO) = 28895576
; ObjectName (RO) = "AcDbPolyline"
; PlotStyleName = "ByLayer"
; Thickness = 0.0
; Visible = -1
T
您可以向其提供可选的第二个参数,该参数使它还列出适用于对象的所有方法。只需在对象名称后面指定:vlax-dump-objectT
(vlax-dump-object WhatsMyLine T)
GMT+8, 2026-11-4 23:21
