ActiveX 开发指南
相关分类
数据库属性 (ActiveX/ATO)
2023-1-1 22:02| 发布者: admin| 查看: 1484| 评论: 0|来自: AutoCAD
摘要: 图形文件的数据库对象。
图形文件的数据库对象。
支持的平台:仅窗口
Namespace:传输利布
组装:acETransmit20.tlb
VBA/VB.NET/C#:
object.database
类型:传递文件
此属性适用的对象。
只读:是的
类型:对象 (AcadDatabase)
对象在 AutoCAD 对象库中定义。AcadDatabse
发布信息
释放:AutoCAD 2005 及更高版本
历史
  • 该界面与 AutoCAD 2010 版本的库中的界面合并。ITransmittalFile2ITransmittalFile
  • 该属性是在 AutoCAD 2005 版本的库中引入的界面。databaseITransmittalFile2
VB.NET:
' Custom command that lists the file dependents
<CommandMethod("FileDependents")> _
Public Shared Sub FileDependents()
    ' Define file to add to the transmittal
    Dim tf As TransmittalFile = Nothing
    Dim dwgFile As String = "C:\AutoCAD\Sample\Sheet Sets\Architectural\A-01.dwg"
    ' Add file to transmittal and parse its information
    If tro.addDrawingFile(dwgFile, tf) = AddFileReturnVal.eFileAdded Then
        ' Get each of the referenced files in the file being added
        Dim tfg As TransmittalFilesGraph = tro.graphInterfacePtr()
        Dim rootTF As TransmittalFile = tfg.getRoot()
        Dim tfList As New List(Of TransmittalFile)()
        tfList.Add(rootTF)
        ' Step through each of the referenced files identified
        While tfList.Count > 0
            tf = tfList(0)
            tfList.RemoveAt(0)
            Dim numberOfDependents As Integer = tf.numberOfDependents
            For i As Integer = 0 To numberOfDependents - 1
                Dim childTF As TransmittalFile = tf.getDependent(i)
                tfList.Add(childTF)
                ' Get the current editor
                Dim acEditor As Editor = Application.DocumentManager.MdiActiveDocument.Editor
                acEditor.WriteMessage(Environment.NewLine + "Dependent file name:" & childTF.sourcePath)
                ' See if the dependent file is a drawing or not
                If System.IO.Path.GetExtension(childTF.sourcePath).ToUpper() = ".DWG" Then
                    ' Get the database of the drawing
                    Dim acDb As AcadDatabase = childTF.database
                    ' If the drawing is not null, display the name sof the layers in the drawing
                    If Not acDb Is Nothing Then
                        acEditor.WriteMessage(Environment.NewLine & "Layer Names:")
                        ' Step through each of the layers
                        For Each acLyr As AcadLayer In acDb.Layers
                            ' Output the names of each layer
                            acEditor.WriteMessage(Environment.NewLine & "  " & acLyr.Name)
                        Next
                    End If
                End If
            Next
        End While
    End If
C#:
// Custom command that lists the file dependents
[CommandMethod("FileDependents")]
public static void FileDependents()
    TransmittalInfo ti = TransInfo(tro.getTransmittalInfoInterface(), @"C:\Users\Public\TransmittalAPITest\");
    // Define file to add to the transmittal
    TransmittalFile tf = null;
    string dwgFile = @"C:\AutoCAD\Sample\Sheet Sets\Architectural\A-01.dwg";
    // Add file to transmittal and parse its information
    if (tro.addDrawingFile(dwgFile, out tf) == AddFileReturnVal.eFileAdded)
        // Get each of the referenced files in the file being added
        TransmittalFilesGraph tfg = tro.graphInterfacePtr();
        TransmittalFile rootTF = tfg.getRoot();
        List<TransmittalFile> tfList = new List<TransmittalFile>();
        tfList.Add(rootTF);
        // Step through each of the referenced files identified
        while (tfList.Count > 0)
            tf = tfList[0];
            tfList.RemoveAt(0);
            int numberOfDependents = tf.numberOfDependents;
            for (int i = 0; i <= numberOfDependents - 1; i++)
                TransmittalFile childTF = tf.getDependent(i);
                tfList.Add(childTF);
                // Get the current editor
                Editor acEditor = Application.DocumentManager.MdiActiveDocument.Editor;
                acEditor.WriteMessage(Environment.NewLine + "Dependent file name:" + childTF.sourcePath);
                // See if the dependent file is a drawing or not
                if (Path.GetExtension(childTF.sourcePath).ToUpper() == ".DWG")
                    // Get the database of the drawing
                    AcadDatabase acDb = childTF.database;
                    // If the drawing is not null, display the name sof the layers in the drawing
                    if (acDb != null)
                        acEditor.WriteMessage(Environment.NewLine + "Layer Names:");
                        // Sstep through each of the layers
                        foreach (AcadLayer acLyr in acDb.Layers)
                            // Output the names of each layer
                            acEditor.WriteMessage(Environment.NewLine + "  " + acLyr.Name);
GMT+8, 2026-9-19 09:16
