在处理图纸集之前触发。 支持的平台:仅窗口 Namespace:传输利布 组装:acETransmit20.tlb 签名VB.NET: Friend Class custom_class_name
Implements ITransmittalSheetSetNotification
Public Sub preSheetSetProcessing(pISheetSet As Object, _
pFile As TransmittalFile, _
pTransmit As TransmittalOperation) _
Implements ITransmittalSheetSetNotification.preSheetSetProcessing
End Class
C#: internal class custom_class_name : ITransmittalSheetSetNotification
public void preSheetSetProcessing(object pISheetSet,
TransmittalFile pFile,
TransmittalOperation pTransmit)
返回值(RetVal)无返回值。 言论没有额外的评论。 发布信息释放:AutoCAD 2005 及更高版本 例子VB.NET: ' Custom class used to monitor the processing of a sheet set
Friend Class MyTransSSMNotifier
pFile As TRANSMITTALLib.TransmittalFile, _
pTransmit As TRANSMITTALLib.TransmittalOperation) _
Implements TRANSMITTALLib.ITransmittalSheetSetNotification.preSheetSetProcessing
Application.DocumentManager.MdiActiveDocument.Editor. _
WriteMessage(Environment.NewLine & "Sheet Set preprocessing: " & pFile.sourcePath)
End Class
C#: // Custom class used to monitor the processing of a sheet set
internal class MyTransSSMNotifier : ITransmittalSheetSetNotification
public void preSheetSetProcessing(object pISheetSet, TRANSMITTALLib.TransmittalFile pFile,
TRANSMITTALLib.TransmittalOperation pTransmit)
WriteMessage(Environment.NewLine + "Sheet Set preprocessing: " + pFile.sourcePath);
GMT+8, 2026-10-28 11:11
