将新节点添加到传递集的文件图时触发。 支持的平台:仅窗口 Namespace:传输利布 组装:acETransmit20.tlb 签名VB.NET: Friend Class custom_class_name
Implements TransmittalAddFileNotificationHandler
Public Sub endFilesGraphCreation(pTransmit As TRANSMITTALLib.TransmittalOperation) _
Implements TRANSMITTALLib.ITransmittalAddFileNotificationHandler.endFilesGraphCreation
End Class
C#: internal class custom_class_name : TransmittalAddFileNotificationHandler
public void endFilesGraphCreation(TRANSMITTALLib.TransmittalOperation pTransmit)
返回值(RetVal)无返回值。 言论没有额外的评论。 发布信息释放:AutoCAD 2004 及更高版本 例子VB.NET: ' Custom class used to monitor files being added to the transmittal package
Friend Class MyTransFileNotifier
Implements TRANSMITTALLib. _
Application.DocumentManager.MdiActiveDocument.Editor. _
WriteMessage(Environment.NewLine + "File graph creation ended.")
End Class
C#: // Custom class used to monitor files being added to the transmittal package
internal class MyTransFileNotifier : TransmittalAddFileNotificationHandler
WriteMessage(Environment.NewLine + "File graph creation ended.");
GMT+8, 2026-10-26 13:00
