将新文件添加到传递集时触发。 支持的平台:仅窗口 Namespace:传输利布 组装:acETransmit20.tlb 签名VB.NET: Friend Class custom_class_name
Implements TransmittalAddFileNotificationHandler
Public Sub addFileNotificationHandler(pFile, pTransmit) _
Implements TRANSMITTALLib.ITransmittalAddFileNotificationHandler.addFileNotificationHandler
End Class
C#: internal class custom_class_name : TransmittalAddFileNotificationHandler
public void addFileNotificationHandler(pFile, pTransmit)
返回值(RetVal)无返回值。 言论没有额外的评论。 发布信息释放:AutoCAD 2004 及更高版本 例子VB.NET: ' Custom class used to monitor files being added to the transmittal package
Friend Class MyTransFileNotifier
' Used to get a notification when a drawing or file is added to the transmittal package
Public Sub addFileNotificationHandler(pFile As TRANSMITTALLib.TransmittalFile, _
pTransmit As TRANSMITTALLib.TransmittalOperation) _
Implements TRANSMITTALLib. _
Application.DocumentManager.MdiActiveDocument.Editor. _
WriteMessage(Environment.NewLine & _
"File added to transmittal package: " & pFile.sourcePath)
End Class
C#: // Custom class used to monitor files being added to the transmittal package
internal class MyTransFileNotifier : TransmittalAddFileNotificationHandler
// Used to get a notification when a drawing or file is added to the transmittal package
public void addFileNotificationHandler(TRANSMITTALLib.TransmittalFile pFile,
TRANSMITTALLib.TransmittalOperation pTransmit)
WriteMessage(Environment.NewLine + "File added to transmittal package: " +
pFile.sourcePath);
GMT+8, 2026-10-27 09:46
