ActiveX 开发指南
相关分类
传递操作对象 (ActiveX/ATO)
2023-1-1 23:13| 发布者: admin| 查看: 1455| 评论: 0|来自: AutoCAD
摘要: 传递引擎的主要对象,用于将文件添加到传递集、注册通知处理程序和创建传递包。
支持的平台:仅窗口
Namespace:传输利布
组装:acETransmit20.tlb
班级信息
类名
TransmittalOperation
对象继承
Object
创建使用
VB.NET
User-defined variable; New TransmittalOperation
C#
User-defined variable; new TransmittalOperation
访问方式
VB.NET
C#
Remarks
The object represents the transmittal object used to create a transmittal package. After the object is created, you can then add drawing and non-drawing files to the transmittal set. The settings of the transmittal set are managed with the object returned by the method. After files have been added and the settings configured, you can then get information about the referenced files with the method or create a transmittal package with the method. TransmittalOperationTransmittalInfogetTransmittalInfoInterfacegetTransmittalGraphInterfacecreateTransmittalPackage
发布信息
释放:AutoCAD 2004 及更高版本
历史
  • Theandinterfaces被合并到AutoCAD 2010版本的库中。ITransmittalOperation2ITransmittalOperation3ITransmittalOperation
  • 该接口已添加到 AutoCAD 2008 版本的库中,以扩展 andinterfaces 的功能。ITransmittalOperation3ITransmittalOperationITransmittalOperation2
    添加了这些方法:
  • 该界面已添加到 AutoCAD 2005 版本的库中,以扩展界面的功能。ITransmittalOperation2ITransmittalOperation
    添加了这些方法:
    addDrawingFile
    addFile
    addSheets
    addSheetSelset
    addToReport
    archiveSheetSet
    cancelDatabaseNotification
    cancelSheetSetNotification
    cancelSubscriptionToAddFileNotification
    getTransmittalReport
    recalcTargetSubPath
    setProgressMeter
    subscribeDatabaseNotification
    subscribeSheetSetNotification
    subscribeToAddFileNotification
GMT+8, 2026-10-27 21:12
