获取对象中的项数。 支持的平台:仅窗口 Namespace:AcStMgr 集会:AcStMgr.tlb 签名VB.NET: object.Count C#: object.Count;
属性值只读:是的 类型:长 对象中的项数。 言论没有额外的评论。 发布信息释放:AutoCAD 2004 及更高版本
例子VB.NET: Public Sub SetupForAudit(ByVal pDb As AcadDatabase, _
ByVal szPathName As String, _
ByVal stdNameArray As Object, _
ByVal stdPathArray As Object, _
ByVal stdDbArray As Object) _
Implements IAcStPlugin2.SetupForAudit
' Number of graphical objects contained in model space and paper space of
' the database being checked
If Not IsNothing(pDb) Then
Dim msProxy As IAcStBlockProxy = m_pManager.ModelSpaceProxy(pDb)
Dim psProxy As IAcStBlockProxy = m_pManager.PaperSpaceProxy(pDb)
Debug.Print("Object counts " & vbLf & "Model: " & msProxy.Count.ToString() &
vbLf & "Paper: " & psProxy.Count.ToString())
End If
C#: public void SetupForAudit(AcadDatabase pDb, string szPathName, object stdNameArray,
object stdPathArray, object stdDbArray)
// Number of graphical objects contained in model space and paper space of
// the database being checked
if (pDb != null)
IAcStBlockProxy msProxy = m_pManager.get_ModelSpaceProxy(pDb);
IAcStBlockProxy psProxy = m_pManager.get_PaperSpaceProxy(pDb);
Debug.Print("Object counts \nModel: " + msProxy.Count.ToString() +
"\nPaper: " + psProxy.Count.ToString());
GMT+8, 2026-10-28 02:43
