在指定节点下创建一个新节点。AcStPluginInfo 支持的平台:仅窗口 Namespace:AcStMgr 集会:AcStMgr.tlb 签名VB.NET: Public Sub WritePluginInfo(pPluginInfoSectionNode) _
Implements IAcStPlugin2.WritePluginInfo
C#: public void WritePluginInfo(pPluginInfoSectionNode)
返回值(RetVal)无返回值。 言论没有额外的评论。 发布信息释放:AutoCAD 2004 及更高版本
例子VB.NET: Public Sub WritePluginInfo(ByVal pPluginInfoSectionNode As Object) _
' Sets the Section node for the XML file output
Dim pSectionNode As IXMLDOMNode = pPluginInfoSectionNode
' Creates a new element
Dim xmlElem As IXMLDOMElement = _
pSectionNode.ownerDocument.createElement("AcStPluginInfo")
' Appends the new element to the XMl file
Dim pPluginInfoElement As IXMLDOMElement = _
pSectionNode.appendChild(xmlElem)
' Writes the plug-in information to the XML file
pPluginInfoElement.setAttribute("PluginName", Name())
pPluginInfoElement.setAttribute("Version", Version())
pPluginInfoElement.setAttribute("Description", Description())
pPluginInfoElement.setAttribute("Author", Author())
pPluginInfoElement.setAttribute("HRef", HRef())
pPluginInfoElement.setAttribute("DWSName", "")
pPluginInfoElement.setAttribute("Status", "1")
' Save a reference to the XML document in a global variable to allow additional information
' to be added to the XML file
m_xmlDoc = pSectionNode.ownerDocument
C#: public void WritePluginInfo(object pPluginInfoSectionNode)
// Sets the Section node for the XML file output
IXMLDOMNode pSectionNode = (IXMLDOMNode)pPluginInfoSectionNode;
// Creates a new element
IXMLDOMElement xmlElem = pSectionNode.ownerDocument.createElement("AcStPluginInfo");
// Appends the new element to the XMl file
IXMLDOMElement pPluginInfoElement = (IXMLDOMElement)pSectionNode.appendChild(xmlElem);
// Writes the plug-in information to the XML file
pPluginInfoElement.setAttribute("PluginName", Name);
pPluginInfoElement.setAttribute("Version", Version);
pPluginInfoElement.setAttribute("Description", Description);
pPluginInfoElement.setAttribute("Author", Author);
pPluginInfoElement.setAttribute("HRef", HRef);
pPluginInfoElement.setAttribute("DWSName", "");
pPluginInfoElement.setAttribute("Status", "1");
// Save a reference to the XML document in a global variable to allow additional information
// to be added to the XML file
m_xmlDoc = pSectionNode.ownerDocument;
GMT+8, 2026-11-1 10:59
