指定加密密码。(已过时) 支持的平台:仅窗口 属性值只读:不 类型:字符串 加密密码。 言论注意:从基于 AutoCAD-2016 的产品开始,使用密码保护图形文件的功能已停止使用。
例子工 务 局: Sub Example_Password()
' This example opens a password-protected file, closes it, and then opens another
' password-protected file.
ThisDrawing.Application.Documents.Open "C:\MyDrawing.dwg", , "MYPASSWORD"
'AutoCAD converts all passwords to uppercase before applying them
ThisDrawing.Close
ThisDrawing.Application.Documents.Open "C:\MyDrawing2.dwg", , "MYSECONDPASSWORD"
Visual LISP: Not available |
GMT+8, 2026-10-27 09:11
