ActiveX 开发指南
相关分类
文件名属性 (ActiveX)
2023-1-2 22:35| 发布者: admin| 查看: 1622| 评论: 0|来自: AutoCAD
摘要: 指定“文件依赖关系列表”中条目的文件名。(已过时)
支持的平台:仅窗口
工 务 局:
object.FileName
类型:文件依赖
此属性适用的对象。
只读:是的
类型:字符串
保存的基本文件名,不带路径。
没有额外的评论。
发布信息
释放:AutoCAD 2000 至 AutoCAD 2017
工 务 局:
Sub Example_FileName()
    ' This example reads information from a File Dependency List
    ' Open a drawing from the sample Sheet Sets that contains xrefs, such as
    ' \Sample\Sheet Sets\Architectural\A-01.dwg
    Dim objFDLCol As AutoCAD.AcadFileDependencies
    Dim objFDL As AutoCAD.AcadFileDependency
    Set objFDLCol = ThisDrawing.FileDependencies
    MsgBox ("The number of entries in the File Dependency List is " & objFDLCol.count & ".")
    Dim strTemp As String
    For Each objFDL In objFDLCol
        strTemp = "Affects graphics?: " & vbTab & objFDL.AffectsGraphics
        strTemp = strTemp & vbCrLf & "Feature: " & vbTab & objFDL.Feature
        strTemp = strTemp & vbCrLf & "FileName: " & vbTab & objFDL.FileName
        strTemp = strTemp & vbCrLf & "FileSize: " & vbTab & objFDL.FileSize
        strTemp = strTemp & vbCrLf & "Fingerprint GUID: " & vbTab & objFDL.FingerprintGuid
        strTemp = strTemp & vbCrLf & "FoundPath: " & vbTab & objFDL.FoundPath
        strTemp = strTemp & vbCrLf & "FullFileName: " & vbTab & objFDL.FullFileName
        strTemp = strTemp & vbCrLf & "Index: " & vbTab & objFDL.Index
        strTemp = strTemp & vbCrLf & "Modified?: " & vbTab & objFDL.IsModified
        strTemp = strTemp & vbCrLf & "ReferenceCount: " & vbTab & objFDL.ReferenceCount
        strTemp = strTemp & vbCrLf & "Timestamp: " & vbTab & objFDL.TimeStamp
        strTemp = strTemp & vbCrLf & "Version GUID: " & vbTab & objFDL.VersionGuid
        MsgBox strTemp
    Next
Visual LISP:
(defun c:Example_FileName()
    ;; This example reads information from a File Dependency List
    ;; Open a drawing from the sample Sheet Sets that contains xrefs, such as
    ;; .\\Sample\\Sheet Sets\\Architectural\\A-01.dwg
    (setq objFDLCol (vla-get-FileDependencies doc))
    (alert (strcat "The number of entries in the File Dependency List is " (itoa (vla-get-Count objFDLCol)) "."))
    (setq strTemp "")
    (vlax-for each-objFDL objFDLCol
        (setq strTemp (strcat "Affects graphics?: " (if (= (vla-get-AffectsGraphics each-objFDL) :vlax-true) "True" "False")))
        (setq strTemp (strcat strTemp
			                           "\nFeature: " (vla-get-Feature each-objFDL)
			                           "\nFileName: " (vla-get-FileName each-objFDL)
			                           "\nFileSize: " (itoa (vla-get-FileSize each-objFDL))
			                           "\nFingerprint GUID: " (vla-get-FingerprintGuid each-objFDL)
			                           "\nFoundPath: " (vla-get-FoundPath each-objFDL)
			                           "\nFullFileName: " (vla-get-FullFileName each-objFDL)
			                           "\nIndex: " (itoa (vla-get-Index each-objFDL))
			                           "\nModified?: " (if (= (vla-get-IsModified each-objFDL) :vlax-true) "True" "False")
			                           "\nReferenceCount: " (itoa (vla-get-ReferenceCount each-objFDL))
			                           "\nTimeStamp: " (itoa (vla-get-TimeStamp each-objFDL))
			                           "\nVersion GUID: " (vla-get-VersionGuid each-objFDL)
        (alert strTemp)
GMT+8, 2026-10-28 23:33
