在当前选择优先选择集更改时触发。 支持的平台:仅窗口 言论显示模式对话框时不会触发任何事件。 例子工 务 局: Private Sub AcadDocument_SelectionChanged()
' This example intercepts a drawing SelectionChanged event.
' This event is triggered when the current selection set in a drawing is modified.
' To trigger this example event: Select or deselect objects in any open drawing
MsgBox "The selection set in a drawing was just changed!"
Visual LISP: Not available |
GMT+8, 2026-10-31 21:24
