在显示模式对话框之前触发。 支持的平台:仅窗口 言论显示模式对话框时不会触发任何事件。 切勿从事件的事件处理程序中发出消息框。BeginModal 例子工 务 局: Public WithEvents ACADApp As AcadApplication ' Use with Application Event Examples
Sub Example_AcadApplication_Events()
' This example intializes the public variable (ACADApp) which will be used
' to intercept AcadApplication Events
' The VBA WithEvents statement makes it possible to intercept an generic object
' with the events associated with that object.
' Before you will be able to trigger any of the AcadApplication events,
' you will first need to run this procedure.
' We could get the application from the ThisDocument object, but that would
' require having a drawing open, so we grab it from the system.
Set ACADApp = GetObject(, "AutoCAD.Application.24")
Private Sub ACADApp_BeginModal()
' This example intercepts an Application BeginModal event. We use a Beep instead of
' a message box to notify the user when the event is triggered, since a message box
' is a modal entity and would cause continuous BeginModal/EndModal events to be triggered.
' This event is triggered when AutoCAD displays a modal dialog.
' To trigger this example event:
' 1) Make sure to run the example that initializes
' the public variable (named ACADApp) linked to this event.
' 2) Use AutoCAD to begin a modal dialog operation.
' For example, use AutoCAD to display a modal file dialog by using File/New
Beep ' A modal dialog is about to be displayed!
Visual LISP: Not available |
GMT+8, 2026-10-30 07:04
