ActiveX 开发指南
相关分类
ARXLoaded Event (ActiveX)
2023-1-3 00:32| 发布者: admin| 查看: 1536| 评论: 0|来自: AutoCAD
摘要: 加载 ObjectARX 应用程序时触发。
支持的平台:仅窗口
工 务 局:
object.ARXLoaded(FullPathName)
类型:应用
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是应用程序。
完整路径名
类型:字符串
已加载的 ObjectARX 应用程序的完整路径和文件名。
显示模式对话框时不会触发任何事件。
工 务 局:
Public WithEvents ACADApp As AcadApplication    ' Use with Application Event Examples
Sub Example_AcadApplication_Events()
    ' This example initializes the public variable (ACADApp), which will be used
    ' to intercept AcadApplication Events.
    ' The VBA WithEvents statement makes it possible to intercept a generic object
    ' with the events associated with that object.
    ' Before you will be able to trigger any of the AcadApplication events,
    ' you will first need to run this procedure.
    ' We could get the application from the ThisDocument object, but that would
    ' require having a drawing open, so we get it from the system.
    Set ACADApp = GetObject(, "AutoCAD.Application.24")
Private Sub ACADApp_ARXLoaded(ByVal AppName As String)
    ' This example intercepts an Application ARXLoaded event.
    ' This event is triggered when AutoCAD loads an ObjectARX application.
    ' To trigger this example event:
    '     1) Make sure to run the example that initializes
    '     the public variable (named ACADApp) linked to this event.
    '     2) Load an ARX application into AutoCAD.
    ' Use the "AppName" variable to notify the user which ARX application was loaded
      MsgBox "AutoCAD just loaded the ARX application: " & AppName
Visual LISP:
Not available
GMT+8, 2026-10-27 09:11
