指定给定 UCS 的Y方向。 支持的平台:仅窗口 属性值只读:不 类型:变体(双精度的三元素数组) 指定给定 UCS 的Y方向的向量 言论如果更改活动 UCS 上的Y矢量值,则必须重置活动 UCS 才能看到更改。若要重置活动的 UCS,请使用该属性。ActiveUCS 注意:此属性的值存储在 UCSYDIR 系统变量中。
例子工 务 局: Sub Example_YVector()
' This finds the current setting of YVector for a given UCS.
' It then changes the YVector and resets the UCS.
Dim viewportObj As AcadViewport
' Set the viewportObj variable to the active viewport
Set viewportObj = ThisDrawing.ActiveViewport
' Define a new UCS and turn on the UCS icon at the origin.
Dim ucsObj As AcadUCS
Dim origin(0 To 2) As Double
Dim xAxisPoint(0 To 2) As Double
Dim yAxisPoint(0 To 2) As Double
origin(0) = 2: origin(1) = 2: origin(2) = 0
xAxisPoint(0) = 3: xAxisPoint(1) = 2: xAxisPoint(2) = 0
yAxisPoint(0) = 2: yAxisPoint(1) = 3: yAxisPoint(2) = 0
Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint, "UCS1")
ThisDrawing.ActiveUCS = ucsObj
viewportObj.UCSIconOn = True
viewportObj.UCSIconAtOrigin = True
ThisDrawing.ActiveViewport = viewportObj
' Display the current setting of the vectors
MsgBox "The current XVector is: " _
& ucsObj.XVector(0) & ", " & ucsObj.XVector(1) & ", " & ucsObj.XVector(2) & vbCrLf _
& "The current YVector is: " _
& ucsObj.YVector(0) & ", " & ucsObj.YVector(1) & ", " & ucsObj.YVector(2), , "YVector Example"
' Change the setting of YVector
Dim newVector(0 To 2) As Double
newVector(0) = -1: newVector(1) = -1: newVector(2) = 0
ucsObj.YVector = newVector
' Reset the active UCS to see the change
MsgBox "The new XVector is: " _
& "The YVector is: " _
Visual LISP: (vl-load-com)
(defun c:Example_YVector()
;; This finds the current setting of XVector for a given UCS.
;; It then changes the XVector and resets the UCS.
;; Set the viewportObj variable to the activeviewport
(setq viewportObj (vla-get-ActiveViewport doc))
;; Define a new UCS and turn on the UCS icon at the origin.
(setq origin (vlax-3d-point 2 2 0)
xAxisPoint (vlax-3d-point 3 2 0)
yAxisPoint (vlax-3d-point 2 3 0))
(setq ucsObj (vla-Add (vla-get-UserCoordinateSystems doc) origin xAxisPoint yAxisPoint "TEST"))
(vla-put-ActiveUCS doc ucsObj)
(vla-put-UCSIconOn viewportObj :vlax-true)
(vla-put-UCSIconAtOrigin viewportObj :vlax-true)
(vla-put-ActiveViewport doc viewportObj)
;; Display the current setting of the XVector
(alert (strcat "The current XVector is: "
"\n" (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-XVector ucsObj)) 0) 2) ", "
(rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-XVector ucsObj)) 1) 2) ", "
(rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-XVector ucsObj)) 2) 2)
"\nThe current YVector is: "
"\n" (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-YVector ucsObj)) 0) 2) ", "
(rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-YVector ucsObj)) 1) 2) ", "
(rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-YVector ucsObj)) 2) 2)))
;; Change the setting of XVector
(setq newVector (vlax-3d-point 0.7071 0.7071 0))
(vla-put-XVector ucsObj newVector)
(setq newVector (vlax-3d-point -0.7071 0.7071 0))
(vla-put-YVector ucsObj newVector)
;; Reset the active UCS to see the change
(alert (strcat "The new XVector is: "
"\nThe new YVector is: "
GMT+8, 2026-10-31 09:43
